Need Configuration example Dial Peer/SIP trunking between CUCM & UCME.
Mar 31st, 2010
I have 2821 CME at remote location and Cisco UCM at Main location.   I need dial peer/SIP trunking over MPLS WAN connection configuration example for this..
DO any have it?  Please suggest any related soultion or exmaple link.
Sandip
Aaron Harrison Thu, 04/01/2010 - 01:29
  • Community Spotlight Award,
    Member's Choice, May 2015
Just use H.323.
1) Add a H.323 gateway to CCM, with the CME IP
2) Point a route pattern at the H.323 gateawy
3) Add a dial-peer on the CME pointing at the CCM IP
4) Add resilient duplicate dial-peers with lower preference pointed at your lower-order call processing CCMs
Aaron
Please rate helpful posts...
Adrian Saavedra Thu, 04/01/2010 - 01:55
  • Gold, 750 points or more
Hi Sandip,
Follow the steps that Aaron said. If you want to check those steps in detail with examples, you can use this documents as a guide:
H.323 Gateway Configuration Between CallManager Express and CallManager
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a00808ebbfe.shtml
H.323 Gateway Dial-Peer Configuration for Cisco CallManager Server Redundancy
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
Hope to help, if it does please rate.
- Adrián.
