VG224 Short Codes
Mar 31st, 2010
Hi Guys,
I'm running  CCM 7 with VG224's setup as mgcp.
All my analogue DECT phones are hanging of the VG224's
The issue that we are experiencing now is that we can't forward or transfer calls from any of these handsets
I know this is a limitation of a VG224.
I read that one can use short codes from the analogue phone to foreward or transfer calls.
But the VG needs to be setup as SCCP not MGCP.
Has anyone done this before?
Is this possible?
Thank you for the help
marius_vt Thu, 04/01/2010 - 01:13
Hi Aaron
Thank you so much for the reply
The sample config is the a VG224 SCCP one
have you came across the short-codes one would use to foreward and transfer calls
Marius van Tonder
Aaron Harrison Thu, 04/01/2010 - 01:24
  • Community Spotlight Award,
    Member's Choice, May 2015
This has an example of the code for call-forward being configured:
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbas...
This page details the default method of transfer (hookflash) and how to set up a code (the example given is '#2 for "transfer"') right near the bottom:
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsscc...
Aaron
Please rate helpful posts...
