Aaron Harrison Thu, 04/01/2010 - 02:34
Yep, if you have qualification and experience that are relevant to it... same as any other field really
Aaron
Aaron Harrison Thu, 04/01/2010 - 02:39
Or put another way - if you are in a job where you are doing a little VoIP work, involve yourself as much as possible in all things related to it, work on your CCVP, and then try your luck.
Aaron
