Apr 1st, 2010
hi guys,
i have one catalyst c3750G-12S-S witch ios: c3750-ipbase-mz.122-46.SE, that when is power-on, the fan try is always for 100%
how to set the fan try to less utilization?
best regards,
tech-intercom Thu, 04/01/2010 - 05:52
"show env all"  has both temperature and fan "OK",
but my problem is the blow of the fan try!, it's always 100% and i think can set with ios command, or not?
Leo Laohoo Thu, 04/01/2010 - 15:54
When you power up a 3750/3750-E the appliance goes into a POST (Power On Self-Test).  The system will send the fan to full power to ascertain it's functionality.  After this stress test the fan will operate at normal level.
Are you asking if there's any way to disable this?  Why?  Where is the appliance located?  Is it located near staffs and employees?
tech-intercom Fri, 04/02/2010 - 05:57
no, my problem is that, after POST, the fan try is always at 100%,  but "sh env all " is always OK
can i set the fan try speed with ios command?
Leo Laohoo Tue, 04/06/2010 - 17:10
No you can't.  You may want to raise a Cisco TAC and have the appliance RMA-ed.
Related Content
