Encapsulation failed arp incomplete
Apr 1st, 2010
Hi All,
Im wondering if someone is able to help with this one. Please view the debug output below
*Mar  1 05:01:07.270: IP: tableid=0, s=119.118.126.234 (local), d=119.118.126.233 (Vlan1), routed via RIB
*Mar  1 05:01:07.270: IP: s=119.118.126.234 (local), d=119.118.126.233 (Vlan1),
*Mar  1 05:01:07.270:     ICMP type=8, code=0
*Mar  1 05:01:07.270: IP: s=119.118.126.234 (local), d=119.118.126.233 (Vlan1),len 100, encapsulation failed
Protocol  Address          Age (min)  Hardware Addr   Type   Interf
Internet  10.199.39.1             -   9caf.ca44.4998  ARPA   Vlan2
Internet  10.199.39.3             0   0003.9d75.20a5  ARPA   Vlan2
Internet 119.118.126.233         0   Incomplete      ARPA
Internet  119.118.126.234         -   9caf.ca44.4998  ARPA   Vlan1
My setup is curentally cabled as follows
<---10.199.20.1--->fe1[Cisco 877] fe0<-----122.41.88.162---------------------122.41.88.163------> [Fiber   box with Ethernet cable] > internet
Does anyone have any idea why my cisco router is unable to add a MAC address entry into the ARP table ?
Just an extra note, the interface on the cisco and the fiberbox (direct connection to the ISP) can be plugged into any other device and it works perfectally responding to pings, it just seems to be an issue with the cisco and the fiber ethernet box.
Have tried changing the cable from Straight to Crossover, no luck.
Have tested with another router and it works fine.
Please refer to my earlier post for the running config. https://supportforums.cisco.com/message/3046160#3046160
Nathan
Ganesh Hariharan Thu, 04/01/2010 - 10:23
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi All,
Nathan
Hi Nathan,
The "encapsulation failed" coming in the log  means that the router knows on which interface it has to send the packet, but does not know how to do it.
In order to troubleshoot check out the below things
1.check show arp and check the arp entry of the fiber interface
2.If it is coming incomplete try clear arp in router and ping the fiber interface ip.
3. while pinging just enable debug arp in router,so that what is happening we can see with the logs.
Hope to Help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
