RME Inventory collection - device sensed, collection failed
Apr 1st, 2010
Hello, i have this problem with
cisco AP12XX. Some of the AP works fine some not.
I have checked the IOS version on two of them (one working and one not) it is the same version 12.3(7)JA1
Thanks a lot for your help
mgoedert Thu, 04/01/2010 - 23:51
Here is my IC_Server.log
The version of RME is 4.0.6
And sorry but the IOS of those AP is 12.2(15)JA
The IP address for the failing AP is
Again thanks a lot for your help, waiting for your answer
Joe Clarke Fri, 04/02/2010 - 00:20
You are seeing a timeout reading the FLASH-MIB.  Increase your SNMP timeout in RME to 10 seconds under RME > Devices > Device Management > RME Devices.  Edit the attributes for this AP, then do an inline edit, and change the timeout.  Be sure to save then apply the changes on the previous window.
Please support CSC Helps Haiti
mgoedert Fri, 04/02/2010 - 00:38
Great job, it works, but as i have 76 AP which behave the same, do i need to change this timeout value individually or is there any global solution to increase the timeout value.
mgoedert Fri, 04/02/2010 - 00:52
Again thanks a lot for your great help, now that i know what to do
i'll manage to make il works.
This case can be closed
Have a nice easter
