anyconnect not working
I want to be able to connect to asa via portal page from any internet location, automatically use anyconnect (no user choice), and have all networks tunneled (access to both the internal 192.168.5.x lan as well as that sites internet connection).  When I login, it starts downloading anyconnect, then I receive a 'can't connect to network' error and it terminates.  It used to work,but I guess the config was not saved and after a reboot it now doesn't work (yeah, I'm kicking myself for that).  Not sure where to look, I think I have been staring at it too long.
ASA Version 8.2(2)
hostname lenny
domain-name default.com
enable password [DELETED]
passwd [DELETED]
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
description wan
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
banner exec Unauthorized access strictly prohibited
banner login Unauthorized Access Prohibited
banner motd Unauthorized Access Prohibited
boot system disk0:/asa822-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 64.59.176.13
name-server 64.59.177.226
object-group service [DELETED]
port-object eq [DELETED]
object-group service [DELETED]udp
description [DELETED]
access-list in_nat0_out extended permit ip any 192.168.5.0 255.255.255.0
access-list outside_access_in remark [DELETED]
access-list outside_access_in extended permit tcp any any eq [DELETED]
access-list outside_access_in extended permit udp any any eq [DELETED]
access-list lan remark all lan
access-list lan standard permit 192.168.5.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool anyvpn_pool 192.168.5.75-192.168.5.80 mask 255.255.255.0
ip local pool anyvpnpool2 192.168.5.81-192.168.5.90 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list in_nat0_out
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface [DELETED]192.168.5.15 [DELETED]netmask 255.255.255.255
static (inside,outside) udp interface [DELETED]192.168.5.15 [DELETED]netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http [DELETED]255.255.255.0 outside
http 192.168.5.0 255.255.255.0 inside
http [DELETED]255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
vpn-addr-assign local reuse-delay 5
telnet 192.168.5.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.5.0 255.255.255.0 inside
ssh timeout 10
ssh version 2
console timeout 5
dhcpd auto_config outside
dhcpd address 192.168.5.50-192.168.5.60 inside
dhcpd dns 192.168.5.1 interface inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable inside
enable outside
csd image disk0:/securedesktop-asa-3.3.0.151-k9.pkg
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc enable
group-policy DfltGrpPolicy attributes
vpn-simultaneous-logins 5
vpn-idle-timeout 20
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
ip-comp enable
split-tunnel-network-list value lan
intercept-dhcp enable
webvpn
  url-list value default
  svc ask none default svc
  hidden-shares visible
username [DELETED]password [DELETED]== nt-encrypted
username [DELETED]attributes
service-type remote-access
username [DELETED]password [DELETED] encrypted privilege 15
tunnel-group DefaultRAGroup general-attributes
address-pool anyvpn_pool
tunnel-group DefaultWEBVPNGroup general-attributes
address-pool anyvpnpool2
tunnel-group Portal type remote-access
tunnel-group Portal general-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
[DELETED]Cryptochecksum:78a02a9a567f683d20af7e824dc3fe2e
: end
lenny#
ksirupa Thu, 04/01/2010 - 23:47
  • Silver, 250 points or more
What does the ASA log show? If you use ASDM->Monitoring->logging->Debug level, it usually prints messages when the client fails to connect.
Kiran
