04-01-2010 08:21 AM - edited 03-14-2019 05:31 AM
using 7.x
I'm playing with an existing script i found to try and upload a document, replacing the original. i see the GetUser -> Create and XML doc, write document to a temp folder/file, create new file doc in the temp folder, upload doc to the original location.
but it then dumps out to unsuccessful. ideas?
are there folder permissions i need to set on uccx, does uccx need to see AD (my cucm is AD integrated).
I'm still new to all this so any help would be appreciated
Solved! Go to Solution.
04-01-2010 08:39 AM
You don't need the write/create file bits.
Just:
Get user
Authenticate User <
04-01-2010 08:39 AM
Just:
Get user
Authenticate User <
