DMP 4400G and Interactive
Answered Question
Apr 1st, 2010
Yesterday I went to Tyco Technologies to test the TouchScreen with DMP4400g.
I turn on the touch screen on DMP, selected the Elo, save, restart and the touch don't works. After restart, on DMP, the driver touch loaded is Elo.
Anybody already tested DMP with Elo Touchscreen?
Peterson
Correct Answer by Tomas De Leon about 7 years 2 months ago
sorry for the confusion, what i meant was for "ELO" touchscreens we only support
APR technologies.  For the other drivers, information can be found here:
http://www.cisco.com/en/US/partner/prod/collateral/video/ps9339/ps7220/data_sheet_c78-480272_ps6681_Products_Data_Sheet.html
Touchscreen support
Vendor
Supported Systems
3M
Touch Sensor and Systems:
3M MicroTouch ClearTek II touch sensor
3M MicroTouch System SCT3250CX
3M MicroTouch Sensor SCT7650
3M MicroTouch System SCT3250SX
3M MicroTouch Capacitive TouchSense System
3M MicroTouch DST touch system
Display Systems:
3M MicroTouch Display M1500SS (15 in.)
3M MicroTouch Display M1700SS (17 in.)
3M MicroTouch CT150 15-in. LCD Touch Monitor
3M MicroTouch ChassisTouch 17-in. LCD Touch Monitor
ELO
All Acoustic Pulse Recognition systems
Zytronics
Zybrid Screen systems
General Touch
All systems supported by the ST6001S controller
Overall Rating: 5 (1 ratings)
Tomas De Leon Mon, 04/05/2010 - 06:25
  • Cisco Employee,
Peterson,
Sorry for the Delay...
Currently, Our DMPs only support ELO APR (Acoustic Pulse Recognition) systems.
Which ELO Touchscreen do you have?  (Model# and Touch Technology)
Also,  How are you connecting the ELO to the DMP?  What Cables are you using?
When the ELO Driver is enabled, saved, and the DMP is restarted;  the DMP & the ELO
must Calibrate first.  You will see a dialog box on the Display.  If you did not see this then, the
two devices have NOT calibrated and the TOUCH portion will NOT work...
Cheers!
T.
pgcristovam Mon, 04/05/2010 - 07:20
Hi Thomas
Yes, I discovered this on last weekend...
I will go on Tyco again on next days, now with ELO APR (Acoustic Pulse Recognition) systems.
But, now, I have another 2 questions:
1 - the ELO APR is proprietary technology so, on DMP has anothers options of Touchscreen like 3M and General Touch, so the touchscreen of this supply don't works?
2 - In what document, the Cisco say that just on ELO APR techonolgy touchscreen, the DMP4400g works? On documentation guide don't say.
Peterson
Correct Answer
Tomas De Leon Mon, 04/05/2010 - 07:39
  • Cisco Employee,
Touchscreen support
Vendor
Supported Systems
3M
Display Systems:
ELO
Zytronics
General Touch
