SFP Moduel Support
ydcnetwork
All,
I have a 3845 router with VPN/K9 and planning to install a SFP card.
1. My last mile connectivity is on Fibre
2. Fibre hand-off will be 100Base-SC Multimode
Which supportive SFP card  will help me in completeting this handoff on my router
If its not supportive what are all the options available like
gopi
paolo bevilacqua
The 3845 does not support 100 mbps SFP, so you will have to use an external converter.
However, the 3925 and 3945 in their E and non-E versions, do support GLC-GE-100FX so they it would a better choice.
