Ganesh Hariharan Fri, 04/02/2010 - 06:20
Does syslog local director support redirectives for different modules, say CSM on a 6509? I want to store CSM syslog in a separate file as to rest of the syslog from 6509.
Check out the below link hope to help !!
http://www.cisco.com/en/US/products/hw/contnetw/ps1894/products_tech_note09186a008009452b.shtml#config_ld
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
normanzhang Tue, 04/06/2010 - 09:29
thx for the url. i don't think there's a sub command with the CSM module that can set separate syslog facility and level. i guess i need to look at syslog server end for the filtering.
Ganesh Hariharan Tue, 04/06/2010 - 21:47
At syslog level you can do just check out the below url with respect to kiwi syslog how to filter as per the severnity level,Hope that help !!
http://www.kiwisyslog.com/kb/how-to:-setup-kiwi-syslog-server-to-log-to-different-virtual-displays/
Ganesh.H
Remember to rate the helpful post
