Rate limiting at vlan interface on Cat6509
Apr 1st, 2010
I would like to rate limit the users on vlan 2099 - it is for guest users.  I have already put a filter on that vlan to limit the protocols and it works fine.  The rate-limiting does not work at all. Can someone tell if I am missing something? vlan access-map Filter_Guest 10 match ip address Guest_WLAN_Restriction action forward ! vlan filter Filter_Guest vlan-list 2099 ip access-list extended Guest_WLAN_Restriction permit udp any any eq bootps permit udp any any eq bootpc permit udp any any eq domain permit tcp any any eq domain permit udp any any eq 80 permit tcp any any eq www permit tcp any any eq 443 deny  ip any any interface Vlan2099 description = Dilbert_Development ip address 10.128.254.254 255.255.255.0 ip helper-address 123.123.133.1 ip helper-address 123.123.32.1 rate-limit input access-group 175 64000 8000 8000 conform-action transmit exceed-action drop rate-limit output access-group 175 64000 8000 8000 conform-action transmit exceed-action drop
Overall Rating: 4 (8 ratings)
Lei Tian Thu, 04/01/2010 - 20:35
  • Cisco Employee,
CAR is the legacy way of doing rate limiting; have you try policy-map and policing instead?
HTH,
Lei Tian
tdennehy Fri, 04/02/2010 - 07:32
I did try a policy-map and policing and it did not work. I believe I had it misconfigured since I read something last night that leads me to that conclusion.
allan.thomas Fri, 04/02/2010 - 03:11
  • Blue, 1500 points or more
The only aspect from your description that I see has no correlation to what you are attempting to limit is the access-group 175.  Under the rate-limit command you specify the match criteria as a specific access-group, do you have the ip access-list 175 configured as it does not appear within the information you have provided?
Allan.
tdennehy Fri, 04/02/2010 - 07:36
Allen,
I forgot to put that in the question.  The ACL is as follows:
access-list 175 permit ip any any
I must be missing something... because it just isn't working!
Tim
tdennehy Fri, 04/02/2010 - 08:29
I found this statement on this webpage:
"In order to enable CAR, you must enable Cisco Express Forwarding (CEF) on the box. In addition, you must configure a CEF-switched interface for CAR"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_not...
I want to enable it on an VLAN, since the machines are downstream and not directly connected to this 6509. The VLAN interface is on the 6509.
James Coyne Fri, 04/02/2010 - 08:45
  • Cisco Employee,
ip access-list extended RATELIMIT
permit ip any any
class-map RATELIMIT
match access group RATELIMIT
policy-map RATELIMIT
class RATELIMIT
  police 64000 8000 8000 conform-action transmit exceed-action drop
int Vlan 2099
service-policy output RATELIMIT
service-policy input RATELIMIT
tdennehy Fri, 04/02/2010 - 09:31
Jim,
I tried that already. My policy is identical to yours, but I plugged yours in just in case I mistyped something. Your policy doesn't work either. I must be missing some other global command is all I can think.
Here's what I have below. I have a laptop on my desk on that vlan, IP is 10.128.254.152, and can hit the speed test site on the internet and has unrestricted downloads and uploads.
mls qos
class-map match-all identify_Guest_WLAN_Ratelimit
match access-group name Guest_WLAN_Ratelimit
class-map match-all RATELIMIT
match access-group name RATELIMIT
policy-map police-WLAN-Guest-traffic
class identify_Guest_WLAN_Ratelimit
police cir 64000 bc 8000 be 8000 conform-action transmit exceed-action drop violate-action drop
class RATELIMIT
interface Vlan2099
ip access-list extended Guest_WLAN_Ratelimit
permit ip any any
permit ip any any
Tim
James Coyne Fri, 04/02/2010 - 09:54
  • Cisco Employee,
What's the output of sh policy-map interface vlan 2099?
tdennehy Fri, 04/02/2010 - 10:29
CSFC6503#sh policy-map interface vlan 2099
Vlan2099
Service-policy input: RATELIMIT
class-map: RATELIMIT (match-all)
Match: access-group name RATELIMIT
police :
64000 bps 8000 limit 8000 extended limit
Earl in slot 5 :
0 bytes
5 minute offered rate 0 bps
aggregate-forwarded 0 bytes action: transmit
exceeded 0 bytes action: drop
aggregate-forward 0 bps exceed 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Service-policy output: RATELIMIT
police :
Earl in slot 5 :
5190 bytes
aggregate-forwarded 5190 bytes action: transmit
0 packets, 0 bytes
Match: any
allan.thomas Fri, 04/02/2010 - 09:55
Hi Tim,
I suspect that object criteria is falling into the class-default which is specifically for traffic that is not specifically classified.  As you have all one class which consist of essentially everything could you try configuring the policy-map as follows so that you only have the class class-default within it, and then try testing again:-
  class class-default
interface Vlan2099
Could you post the show policy-map, and show interface policy-map command.
Allan.
tdennehy Fri, 04/02/2010 - 11:05
Allen,
Here is what the config looks like now:
class class-default
permit ip any any
interface Vlan2099
CSFC6503#sho policy-map
Policy Map police-WLAN-Guest-traffic
Class identify_Guest_WLAN_Ratelimit
Policy Map RATELIMIT
Class class-default
Vlan2099
class-map: class-default (match-any)
Match: any
police :
Earl in slot 5 :
0 bytes
Match: any
police :
Earl in slot 5 :
602 bytes
aggregate-forwarded 602 bytes action: transmit
CSFC6503#
allan.thomas Fri, 04/02/2010 - 12:34
Hi Tim,
From the show policy-map interface vlan2099, the outbound service-policy appears to have bytes matched.  To specifically test whether the policed cir is working you could revise the policy so that the conform action is set to drop, this will ensure that any traffic matched which conforms within the CIR is dropped directly.
This would prove that the policy is working as desired and that the your testing is not exceeding the CIR.  I would also configure the access-list to be more explicit and configure it so initially only your testing IP host is configured to any, and any to your IP host.  The example I provided in my previous post simply negates the requirement to have a separate access-list to match-on as the class class-default provides the same catch-all.
Allan.
tdennehy Fri, 04/02/2010 - 12:39
Allan,
I have another box that I use for testing, and I applied the config to it and it works. The main difference is the machine I'm hitting the bandwidth server is on copper, plugged into a copper port on the 6509.
The box that isn't working is a user that enters the box through a vlan trunk. What are the odds that traffic entering through a trunk isn't supported?
I'm going to go prove my theory in a few minutes.
Tim
allan.thomas Fri, 04/02/2010 - 13:20
Hi Tim,
That shouldn't be a problem, if that is the case, then I assume that you have not configured the physical trunk interface on the 6500 for vlan based QoS?  If you haven't could add this command 'mls qos vlan-based' to the appropriate interface and try your tests again?
Allan.
tdennehy Fri, 04/02/2010 - 14:02
Allen,
I just plugged in to gig5/2 on this 6509, configured the port and hit the bandwidth test site from my laptop and was unrestricted.
Te policy did not do anything to my knowledge. There is a FWSM in this 6509 which all traffic default-routes to. That's vlan 30. Traffic comes out on vlan 31, then goes out of the box on port channel 10. I'm thinking the QoS has to be placed on the vlan before it leaves for vlan 30, the default gateway. The traffic comes in to vlan 3099 from a WiSM that is in this chassis. Of course vlan 3099 is trunked, and the traffic flows normally from the laptop when connected to the wlan which is mapped to vlan 3099.
Why that would break it is beyond me, but it might? I'm at a loss as to where I would place 'mls qos vlan-based'. Sorry for the headache you are about to get...
Tim
firewall module 9 vlan-group 1
firewall vlan-group 1 30,31
vlan 30
name inside_fwsm
vlan 31
name outside_fwsm
interface Port-channel10
switchport
switchport trunk allowed vlan 31
switchport mode trunk
mtu 9216
no ip address
load-interval 30
mls qos
no mls flow ip
no mls acl tcam share-global
mls ip multicast flow-stat-timer 9
mls cef error action freeze
vlan 3099
name ELL_Dilbert_Development
class RATELIMIT
police cir 64000000 bc 32000 be 32000 conform-action transmit exceed-action drop violate-action drop
interface GigabitEthernet5/2
switchport
switchport access vlan 3099
switchport mode access
no ip address
media-type rj45
interface Vlan3099
ip address 10.130.254.254 255.255.255.0
ip helper-address 129.237.133.1
ip helper-address 129.237.32.1
permit ip any any
allan.thomas Fri, 04/02/2010 - 14:31
Hi Tim,
I think essentially as you are concerned with limiting traffic from the WiSM coming in on interface GigabitEthernet 5/2 within VLAN 3099, then this should be the inferace where you apply the 'mls qos vlan-based'.
Allan.
Hope this help, pls rate helpful posts.
tdennehy Fri, 04/02/2010 - 14:38
Allen,
The gig port 5/2 is a copper port that I plugged my laptop in and placed it in vlan 3099 to test. The policy didn't work when I was hard wired in. Gig port 5/2 is a user port, not a trunk port. The WiSM creates a dynamic trunk that cannot be modified, so I don't know how I would place a command on a trunk port that is created automagically.
The problem still exists - I can't even get the laptop on gig5/2 to get policed. I placed the port in vlan 3099 and it is not restricted at all. There must be some other global command that I'm missing, I guess.
Tim
Lei Tian Fri, 04/02/2010 - 15:29
  • Cisco Employee,
Hi Tim,
As Allen suggested, apply vlan-based under the physical interfaces. For testing purpose, you can lower the policer's cir, so that is easier to see the result.  Also vlan-based might not work on intra-vlan traffic; if you want restrict traffic within the vlan you might need to use user based or microflow policing.
HTH,
Lei Tian
tdennehy Fri, 04/02/2010 - 16:02
My brain is full, so I'm going to have to pick this up on Monday.
Thanks for all your help so far.  You guys rock!
tdennehy Fri, 04/02/2010 - 16:04
How do I rate helpful posts, by the way?
And thanks for all your help today.  I'm sure I'll get it figured out on Monday thanks to you!
allan.thomas Fri, 04/02/2010 - 16:39
Hi Tim,
Hmmm this is rather strange behaviour, I would expect service-policy on the SVI to be applicable to traffic on ingress from VLAN3099?  I assume the SVI 3099 is the default-gateway for VLAN3099 traffic from the WiSM?  If the PC was connected to this Gigabit5/2 interface as an access, then the ACLs applied on the SVI would take precedent and police the traffic accordingly with vlan-base qos applied to the interface?
As I'm not familiar with how the WiSM trunk interface is negotiated, an alternative would be to match the input-interface instead of a given as access-group as shown below.  However this requires mls qos vlan-based applied to interface as stipulate previously, whether the object match criteria is an access-group or particualr interface/trunk the behaviour or outcome should still be the same.
match input-interface GigabitEthernet5/2
class RATELIMIT
interface vlan3099
Rating posts is simply a case of clicking on the appropriate star to merit the level of helpfulness provided.
Allan
tdennehy Mon, 04/05/2010 - 09:54
Allen,
I just put the following commands into the 6509, and plugged a laptop into gig7/11. Speed test indicates the policy is working one way... I can download at about 1.5 mb/s, but uploading to our bandwidth server is unrestricted. I figured I would fix it first going through the copper, then after I get it working, to look at the WiSM end.
Do you know if this is only supported one way? Sure looks that way...
Tim
class RATELIMIT
police 4000000 32000 32000 conform-action transmit exceed-action drop
interface GigabitEthernet7/11
switchport
no ip address
load-interval 30
interface Vlan3099
permit ip any any
tdennehy Mon, 04/05/2010 - 11:47
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version
12.2(18)
System image file is
"sup-bootdisk:s72033-ipservicesk9_wan-vz.122-18.SXF11.bin"
tdennehy Tue, 04/06/2010 - 15:03
Here's what I ended up with for a solution below. Basically, I could
not put "mls qos vlan-based" on the trunk port because it is a WiSM and
it is a dynamic trunk that is not configurable. So I ended up deploying
the policies on the vlans, 3099 is in the trunk to a wlan, and vlan 30
is the vlan that is the gateway to the FWSM - and eventually the
Internet. So it works. A wlan user on the SSID mapped to vlan 3099
gets policed to about 2mb/s, not 4mb/s as the policy is written.
Another thing I noticed is that when I plug my laptop into a copper port
on the 6509, I can only get a 1 mb/s connection to our bandwidth server.
Strange, but good enough for me.
I was thinking of taking an 8 port 3560 and trunking it to the 6509 and
placing the "mls qos vlan-based" command on that switch just to see if
it works. If not, I'll stick with what I have configured right now.
class-map match-all Identify_WLAN_Guest_outbound
match access-group name Guest_WLAN_UBRL_Outbound
class-map match-all Identify_WLAN_Guest_inbound
match access-group name Guest_WLAN_UBRL_Inbound
policy-map police_WLAN_Guest_traffic_outbound
class Identify_WLAN_Guest_outbound
drop
policy-map police_WLAN_Guest_traffic_inbound
class Identify_WLAN_Guest_inbound
drop
ip access-list extended Guest_WLAN_UBRL_Outbound
permit ip 10.130.254.0 0.0.0.255 any
ip access-list extended Guest_WLAN_UBRL_Inbound
permit ip any 10.130.254.0 0.0.0.255
interface Vlan3099
service-policy output police_WLAN_Guest_traffic_inbound (dnld police)
interface Vlan30
service-policy output police_WLAN_Guest_traffic_outbound (upld police)
ericgarnel Wed, 01/12/2011 - 12:36
  • Gold, 750 points or more
If I understand your config statements correctly, you are defining the acl for the entire subnet and then policing per flow?   Not sure why it is capping at 2 instead of 4.
We are looking to do something similar, but for a larger address space.  I would love to get away with a single acl for the whole subnet.
tdennehy Wed, 01/12/2011 - 16:30
Yes, I am doing the entire subnet.  It is working fine, actually
I did get different bandwidth results from what was configured, so I just bumped it up a bit until I got the desired bandwidth limitation and left it there.
