ASA Logging
Answered Question
Apr 1st, 2010
Does the ASA keep logs of SSL connections? If so, can I get history detail and go back as far as 2009?
What about remote access user detail?
Also, I’d like to automate the delivery of that logging  information into Splunk. What options do I have?
GLH
Correct Answer by Federico Coto F... about 6 years 10 months ago
Hello Greg,
In this case or any other case if you find the answer helpful, you can rate the answer by marking the question as correct.
This will also allow everybody else to know the resolution for this particular issue.
Thank you,
Federico.
Correct Answer by trippi about 6 years 10 months ago
Greg,
Don't forget to give Federico a good vote
Overall Rating: 5 (5 ratings)
Federico Coto F... Thu, 04/01/2010 - 15:04
The ASA keeps logs of remote access connections.
You can't go back to 2009 unless you keep a syslog server with the log files.
The ASA by default log to its console, you can check them via a terminal session as well.
The ASA can log to its buffer, but there's a limit to the amount of logs, and the ASA will just re-write the old logs with the new ones.
Take a look at this link:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/monitor_syslog.html
Federico.
GREG HARPER Fri, 04/02/2010 - 06:39
Thanks Federico for the link and the information.  This helps a bunch!
glh
Correct Answer
trippi Fri, 04/02/2010 - 11:17
Greg,
GREG HARPER Sat, 04/03/2010 - 09:20
Trippi -
Here is a dumb question how do I give him a vote? I logged in and couldn't
find where to vote.
Greg
Correct Answer
Federico Coto F... Sat, 04/03/2010 - 10:11
Hello Greg,
Thank you,
Federico.
