Allowing inside clients access to a static NAT translation device via the public IP
Answered Question
Apr 1st, 2010
Hello
I have a cable ISP connection with a dynamically provided public ip address. From outside the devices are reachable but from inside i cannot reach the external ip. I have an PIX 501 running 6.3.5 and PDM 3.0(4). How can i configure the PIX to let internal clients reach the external ip address and associated ports from inside? Also I am doing all of this via CLI because I can not get PDM to load past the second browser screen it opens detailing versions of OS, IE, Jave, etc.  I can SSH or telnet via the inside IP network.   Below is my current configuration THANKS IN ADVANCE.
: Saved
: Written by enable_15 at 11:09:45.577 pst Thu Apr 1 2010
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ???????????? encrypted
passwd ???????????? encrypted
hostname ZZZZ-CA-FW
domain-name XXXXX.com
clock timezone pst -8
clock summer-time PDT recurring
fixup protocol dns
no fixup protocol ftp 21
no fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
no fixup protocol http 80
no fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
no fixup protocol sqlnet 1521
no fixup protocol tftp 69
names
object-group service allowed_ports tcp
port-object range 7770 7782
access-list out2in permit icmp any any echo-reply
access-list out2in permit icmp any any time-exceeded
access-list out2in permit tcp any any object-group allowed_ports
pager lines 24
logging on
logging timestamp
logging console warnings
logging monitor warnings
logging buffered warnings
logging history warnings
logging facility 18
icmp deny any echo outside
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.128.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.128.1 255.255.255.255 inside
pdm logging warnings 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.128.0 255.255.255.0 0 0
static (inside,outside) tcp interface 7781 192.168.128.21 7781 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7782 192.168.128.22 7782 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7779 192.168.128.19 7779 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7778 192.168.128.18 7778 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7776 192.168.128.16 7776 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7775 192.168.128.15 7775 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7774 192.168.128.14 7774 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7773 192.168.128.13 7773 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7772 192.168.128.12 7772 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7770 192.168.128.10 7770 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 7780 192.168.128.20 7780 netmask 255.255.255.255 0 0
access-group out2in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
ntp server 209.81.9.7 source outside
ntp server 204.152.184.72 source outside
http server enable
http 192.168.128.0 255.255.255.0 inside
snmp-server location garage
snmp-server contact hounds
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.128.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.128.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
dhcpd address 192.168.128.100-192.168.128.150 inside
dhcpd dns 208.67.222.222
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
username admin password ??????????? encrypted privilege 15
terminal width 80
banner exec UNAUTHORIZED ACCESS WILL BE PROSECUTED
banner login UNAUTHORIZED ACCESS WILL BE PROSECUTED
banner motd UNAUTHORIZED ACCESS WILL BE PROSECUTED
: end
Correct Answer by Kureli Sankar about 6 years 10 months ago
Correct. If you were running 7.x code or above may be we can do some destination NAT and same security intra interface and make this work but, not with the code that you are running.
Besides, the right way is to access the inside hosts by the inside IP addresses and not using the translated addresses.
-KS
Overall Rating: 5 (1 ratings)
Kureli Sankar Thu, 04/01/2010 - 18:02
How can I configure the PIX to let internal clients reach the external ip address and associated ports from inside?
I am not sure if I understand the above question.
The config looks correct.
enable buffered logging and see what the log says
conf t
loggging buffered 7
sh logg | i x.x.x.x
where x.x.x.x is the IP address of the client where you are testing the flow.
-KS
rm760 Thu, 04/01/2010 - 18:58
Here is the log @ level 7
IP address 76.166.107.141 is my current dynamic IP address provided by my ISP. Below is the output of sh log.  Please enlighten me as to what I am missing.  Also any help getting PDM to work would be appreciated as well.
Syslog logging: enabled
Facility: 18
Timestamp logging: enabled
Standby logging: disabled
Console logging: level warnings, 344 messages logged
Monitor logging: level warnings, 0 messages logged
Buffer logging: level debugging, 459 messages logged
Trap logging: disabled
History logging: level warnings, 344 messages logged
Device ID: disabled
168.128.113/49653 (76.166.107.141/6276)
302016: Teardown UDP connection 22071 for outside:208.67.222.222/53 to inside:192.168.128.113/49653 duration 0:00:01 bytes 112
305011: Built dynamic TCP translation from inside:192.168.128.113/3120 to outside:76.166.107.141/16661
302013: Built outbound TCP connection 22072 for outside:76.166.107.141/7781 (76.166.107.141/7781) to inside:192.168.128.113/3120 (76.166.107.141/16661)
710005: UDP request discarded from 192.168.128.25/2190 to inside:192.168.128.255/2190
111009: User 'enable_15' executed cmd: show logging
710005: UDP request discarded from 192.168.128.113/138 to inside:192.168.128.255/netbios-dgm
710005: UDP request discarded from 192.168.128.113/137 to inside:192.168.128.255/netbios-ns
305012: Teardown dynamic UDP translation from inside:192.168.128.14/2588 to outside:76.166.107.141/6275 duration 0:00:31
305012: Teardown dynamic TCP translation from inside:192.168.128.14/2587 to outside:76.166.107.141/16660 duration 0:00:31
302016: Teardown UDP connection 22049 for outside:208.54.4.1/500 to inside:192.168.128.112/500 duration 0:02:01 bytes 1457
305011: Built dynamic UDP translation from inside:192.168.128.113/63651 to outside:76.166.107.14 1/6277
302015: Built outbound UDP connection 22073 for outside:208.67.222.222/53 (208.67.222.222/53) to inside:192.168.128.113/63651 (76.166.107.141/6277)
302016: Teardown UDP connection 22073 for outside:208.67.222.222/53 to inside:192.168.128.113/63651 duration 0:00:01 bytes 96
305011: Built dynamic TCP translation from inside:192.168.128.113/3121 to outside:76.166.107.141/16662
302013: Built outbound TCP connection 22074 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3121 (76.166.107.141/16662)
305011: Built dynamic TCP translation from inside:192.168.128.113/3122 to outside:76.166.107.141/16663
302013: Built outbound TCP connection 22075 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3122 (76.166.107.141/16663)
305011: Built dynamic TCP translation from inside:192.168.128.113/3123 to outside:76.166.107.141/16664
302013: Built outbound TCP connection 22076 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3123 (76.166.107.141/16664)
305011: Built dynamic TCP translation from inside:192.168.128.113/3124 to outside:76.166.107.141/16665
302013: Built outbound TCP connection 22077 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3124 (76.166.107.141/16665)
305011: Built dynamic TCP translation from inside:192.168.128.113/3125 to outside:76.166.107.141/16666
302013: Built outbound TCP connection 22078 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3125 (76.166.107.141/16666)
305011: Built dynamic TCP translation from inside:192.168.128.113/3126 to outside:76.166.107.141/16667
302013: Built outbound TCP connection 22079 for outside:83.167.233.50/80 (83.167.233.50/80) to inside:192.168.128.113/3126 (76.166.107.141/16667)
302014: Teardown TCP connection 22074 for outside:83.167.233.50/80 to inside:192.168.128.113/3121 duration 0:00:01 bytes 19263 TCP FINs
305012: Teardown dynamic UDP translation from inside:192.168.128.112/500 to outside:76.166.107.141/29 duration 0:02:06
302014: Teardown TCP connection 22075 for outside:83.167.233.50/80 to inside:192.168.128.113/3122 duration 0:00:01 bytes 1759 TCP FINs
302014: Teardown TCP connection 22078 for outside:83.167.233.50/80 to inside:192.168.128.113/3125 duration 0:00:01 bytes 2271 TCP FINs
302014: Teardown TCP connection 22077 for outside:83.167.233.50/80 to inside:192.168.128.113/3124 duration 0:00:01 bytes 1982 TCP FINs
302014: Teardown TCP connection 22076 for outside:83.167.233.50/80 to inside:192.168.128.113/3123 duration 0:00:01 bytes 3819 TCP FINs
302014: Teardown TCP connection 22079 for outside:83.167.233.50/80 to inside:192.168.128.113/3126 duration 0:00:01 bytes 3861 TCP FINs
Kureli Sankar Thu, 04/01/2010 - 19:37
What is breaking or not working? Inside hosts are unable to go out to the internet? What flow did you test?
What is the source IP address? Is it this 192.168.128.113?
What is the destination address that you tried to reach on the internet? Is it this 83.167.233.50?
The inside host 128.113 was translated to 76.166.107.141 as expected correct?
-KS
rm760 Thu, 04/01/2010 - 20:25
Inside hosts can can browse the internet no problem. The problem is when inside host 192.168.128.113 trys to access http://76.166.107.141:7781 which is actually a device on the inside network that is NAT'd to the outside.
Kureli Sankar Thu, 04/01/2010 - 20:48
Inside hosts should access the inside hosts only using the inside IP addresses and not the translated addresses.
This is not possible.
-KS
rm760 Thu, 04/01/2010 - 20:52
Is this not possible due to a limitation in the PIX?  This used to work when I was using a linksys RV016 as my firewall / switch via port forwarding.  Am I not forwarding correctly in the PIX?
Correct Answer
Kureli Sankar Thu, 04/01/2010 - 20:55
-KS
rm760 Thu, 04/01/2010 - 21:01
We have a webmaster who likes to check and confirm that the devices translated work via the outside interface. Thank you for the effort and responses
Rodrigo Gurriti Fri, 04/02/2010 - 16:10
I had this type of problem before... I tricked the clients inside thru the DNS that pointed to the inside network and they never had to come out the outside interface to come back around. lol worked but was a pain
rm760 Fri, 04/02/2010 - 20:08
Thank you but tried this method.  Our webmaster actually uses the public IP address to check on the sites.
rm760 Tue, 04/06/2010 - 14:30
Collin;
Thanks for DNS doctoring thought.  I thought of this as well but my webadmin tests via the public facing IP address so this is out of the question.
Related Content
