Rate Limit over MQS
Apr 1st, 2010
Hi All,
Iam new to QOS, i have read about rate limit command recently and some basic concept about MQS
As of my knowledge QOS will be used only when only there is congestion, Am i right ?
If i had Rate limit command which matches RTP port with some X bps and Y BC and BE applied to an serial interface in output direction
If there is MQS for same rtp port with classmap policy map and service policy assosiated to same interface in the same direction as like rate limit
which will have impact or which will function and which will not
What will be the result
Hari
Overall Rating: 2 (1 ratings)
Lei Tian Thu, 04/01/2010 - 20:29
  • Cisco Employee,
Hi Hari,
As far as I know, you cannot use both MQC and legacy qos same time.
HTH,
Lei Tian
harisivaji Thu, 04/01/2010 - 23:18
Oh, I didnt try this so i have no idea about this, the reason for this one is due to this requirement:
In my network there are three departments each one has its own VOIP network on its own.
I have to limit bandwidth for each department, like the maximum usuage of bandwidth is limited for Dept-A eg:512Kbps also inside that department where there will be some Voice and data traffic so when there is congestion Voice network in Dept-A can use reserved BW of 128Kbps and data can be used for rest
Simlarly Dept-B and C
I thought first based on network i will rate-limitso maximum ususage is limited
and for Voice priority i plan to use class-map and so... (because i learned QOS will be used st the time of congestion)
Lei Tian Fri, 04/02/2010 - 19:42
  • Cisco Employee,
You can use hierarchical qos to do that. It will be something look like this
policy-map LLQ
class PQ
priority 128k
class class-default
fair-queue
policy-map parent_level
class Dept_A
bandwidth 512k
service-policy LLQ
class Dept_B
bandwidth 512k
service-policy LLQ
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support_ps10591_TSD_Products_Configuration_Guide_Chapter.html#wp1088100
HTH,
Lei Tian
