SDM help
Apr 1st, 2010
I've just purchased an 1841 router but I can't make SDM work properly. It loads fine, but not all 'config' buttons work. On the 'Intrusion Prevention' button it sais to increase java heap size to 256MB and I did, but no change. The thing is that I have also installed ASDM for an ASA and that runs just perfect. Can anyone help me??
manzicu_andrei_pl Sat, 04/03/2010 - 05:10
thanks, but this isn't the answer i was looking for .
I really want to make it work.
should I install it in flash?
Paolo Bevilacqua Sat, 04/03/2010 - 10:55
What I'm trying to tell you is that basically, does not work.
So just use CLI like everybody else.
Nael Mohammad Mon, 04/26/2010 - 17:00
Download CCP and use the JRE java 6 update 17 for use with it. If you have a higher version of JRE, it will not work.  CCP is the replacement for SDM since the product is end of life .
