04-02-2010 04:41 AM - edited 03-10-2019 04:56 AM
Hi everybody!
I have ASA5520 version 8.2(1) with AIP-SSM-20 module
and I want to upgrade AIP-SSM-20 software from version 6.1(3)E3 to 7.0(2)E4
I go to the download site and see the following list:
Intrusion Prevention System (IPS) Recovery Software:
Release Date: 29/Mar/2010
IPS Recovery Image File
Intrusion Prevention System (IPS) Signature Updates:
Release Date: 31/Mar/2010
E4 Signature Update S481
Intrusion Prevention System (IPS) System Software:
IPS-SSM_20 System Image File
Intrusion Prevention System (IPS) System Upgrades
IPS 7.0 Major Upgrade File (All Supported Platforms Except AIM-IPS and NME-IPS)
IPS E4 Engine Update
I am somewhat confused by the number of files and want to ask what the procedure/sequence I should follow to upgrade?
Solved! Go to Solution.
04-02-2010 05:51 AM
This is the file that you would like to use to upgrade it:
IPS-K9-7.0-2-E4.pkg
To upgrade:
1) Upload the "IPS-K9-7.0-2-E4.pkg" file through IDM
2) IDM --> Configuration --> Sensor Management --> Update Sensor --> choose Update is located on this client --> choose the "IPS-K9-7.0-2-E4.pkg" file --> hit the "Update Sensor" button.
It will take a while (around 20 minutes) to upgrade the sensor, so don't panic if it doesn't come back up in "UP" status straight away.
Hope that helps.
04-02-2010 05:51 AM
IPS-K9-7.0-2-E4.pkg
To upgrade:
Hope that helps.
04-02-2010 08:48 AM
Thank you very much for help.
