WCS and Guest account / limited usage web authentication
Answered Question
Apr 2nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Here my problem I need to be able to limit my AD users to a 10min access to the WLAN.  I see you can do this for guest accounts, but you have to manually enter a username and password.  I would like the web authentication to use our ACS which is tied in to our AD.   Is there a way to do this?
Correct Answer by weterry about 6 years 12 months ago
Do you want to limit everyone to 10 minutes?  Session timeout on the WLAN would cause everyone to have to reauthenticate after the specified period of time.
If you only want specific users to do 10 minutes, I'm not really sure how. AAA Override with Radius I think can let you set a session timeout as well, but I don't know if this work with WebAuth....
Overall Rating: 5 (1 ratings)
Correct Answer
weterry Fri, 04/02/2010 - 22:52
  • Silver, 250 points or more
stevechapman_2 Tue, 04/06/2010 - 06:11
Weterry,
Here the whole story.  I have a bookstore that going to have “Demo” pc for students to buy.  The want to show the internet on these devices, but our security guy require all users to logon.  I was hoping to find a way to let user logon quickly to test these devices.
I have already figure out the web auth and that great feature, but you have to manually enter each user.   If I could get that to use AD and limit each to 10min that would be great. I would like to setup a SSID for the demo devices and limit users to 10 min.
I have 2 WiSM controllers running 6.0 also have WCS .
Chappy
stevechapman_2 Tue, 04/06/2010 - 07:17
Weterry,
Thanks for the ideas I got it to work !!!  Here what I did.  Under the WLAN ssid under security tab then AAA servers I selected order used for auth and set it to radius.
Then under Advanced tab I did Allow AAA override enable and set the session timeout to 300 sec (5 min) and it works.  After 5 min I have to reauth via web.
Chappy
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
