value of ccna
Apr 2nd, 2010
I have been studying for ccna off and on for 2 years while working as network admin for last 6 years.  Decided to take test again and failed 770/825!  I want to scream! i have been putting off learning more advanced features to focus on core of CCNA.  Now debating its value.  I do give up and move on with higher level features.  I dont think that i can look at ccna material anymore.... Can anyone recommend good exam sims?
Overall Rating: 3.5 (2 ratings)
Ganesh Hariharan Fri, 04/02/2010 - 09:37
" MyPowerPass" is the best simulator out there for the money (full version is like 20 dollars, or you can use their demo for free).  They give you over 300 questions, and the material to be pretty accurate.
Hope to Help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Reza Sharifi Fri, 04/02/2010 - 09:48
Hi Aaron,
Sorry you did not pass this time but keep at it until you pass. I know the feeling but do not give up.  Also to go for other certification i.e CCNP, you still need to have a valid CCNA.  Look at this way, once you done with CCNA, you will have good foundation for other certifications.
Good Luck,
Reza
When your that close to passing it is likely that you are simply missing a couple key elements to passing.
Boson.com has a full array of exam sims and simulators.  the CCNA one is like 100USD and has 6 exams with options for random exams and 2 modes.  Study mode and Test Simulation mode.
The test process also has a post test wrap up that can show you how well your hitting various elements.
As a means of helping I would also recommend the following be memorized and then immediately written down for testing:
A) 10.0.0.0 - 10.255.255.255
B) 172.16.0.0 - 172.31.255.255
C) 192.168.0.0 - 192.168.255.255
7- Application
6- Presentation
5- Session
4- Transport (segment)
3- network (packet) -- aka internet
2- data link (frame)       \
1- physical                   / 1+2 = network access layer
Connected 0                 static 1
external bgp 20              internal eigrp 90
igrp               100           ospf      110
is-is          115               rip 120
external eigrp 170          internal bgp 200
               unknown 255
stp
blocking -> listening -> learning -> forward
rstp
discard -> learning -> forwarding
dhcp
discovery -> offer -> request -> pack (or PNAK for timeout denials)
32  24       1          255
31  23        2          254
30  22         4          252
29  21          8          248
28  20          16          240
27  19          32          224
26  18          64          192
25  17          128          128
If you can copy that out from memory for reference during a test you should be able to get most of the answers right just from applying this.
