Crypto IOS image
Apr 2nd, 2010
If an image has a (K9)  (c2960-lanbasek9-mz.122-52.SE.bin) does it mean that it has encryption higher than 64bit?
I'm trying to find an image (for Cisco 2960) with upto (or less than) 64 bit encryption that can at least support SSH but no luck.
Any clue?
Ganesh Hariharan Fri, 04/02/2010 - 09:50
Any clue?
Yes K9 image mean cryptographic image and it supports more than 64 bits,like 128 and 1024 bits to genrate RSA key pair.But this image should support ssh.
Check out the below link on ssh configuration in 2960 switches
http://www-europe.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_sed/configuration/guide/swauthen.html#wp1204672
Hope to Help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
chettym5 Mon, 10/06/2014 - 03:41
hi
on the EI-3000-4TC switch software options :
 what is the web based dev mgr?
alternatively, the difference between ;
1. Cisco IE 3000 LAN Base with web based dev manager
2. LAN base W/O crypto with web based dev manager
