04-02-2010 09:41 AM
Does anyone have a clear example of a full configuration including the "portmap vip-address-range" Command? I've done plenty of searches and the best I can come up with is a description along with the CLI command. No where can I find a full configruation example of a CSS using the portmap.
Solved! Go to Solution.
04-07-2010 02:18 AM
Here is the information I have
Here is a configuration example of a Source Group with 3 VIP addresses:
(config)# group ftpgroup
(config-group[ftpgroup])# vip address 192.168.1.10
(config-group[ftpgroup])# portmap vip-address-range 3
(config-group[ftpgroup])# add destination service ftp-svc1
(config-group[ftpgroup])# add destination service ftp-svc2
(config-group[ftpgroup])# active
But, the whole concept of range on the CSS is not very helpful.
If you want to use a range, you need to apply the same range command to vip, group AND service.
Then, when a user comes to vip range X, we select service range X, and group range X....the same index in each.
Gilles.
04-07-2010 02:18 AM
Gilles.
04-07-2010 06:06 AM
Thanks for the comment. Yes, I'll gladely say the documentation available for this command
is VERY lacking. I did figure out what your saying on my own, but it took some time.
Thanks again.
