Attempting to trunk a 2924xl to a 3550
Answered Question
Apr 2nd, 2010
I have a 3550 and 2924xl switch I want to trunk together but am unsuccefule thus far:
The 3550 is as follows:
Model number: WS-C3550-24-EMI
System image file is "flash:c3550-i5q3l2-mz.121-14.EA1a/c3550-i5q3l2-mz.121-14.EA1a.bin
cisco WS-C3550-24 (PowerPC) processor (revision K0) with 65526K/8192K bytes of memory.
The 2924 is as follows:
Model number: WS-C2924-XL-A
System image file is "flash:c2900XL-h2-mz-112.8.2-SA6.bin", booted via administrator on vty0 (172.16.204.213)
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
With the 2924XL access port set to access, I can access it. Setup in multi mode with vlans permitted from the 3550, I cannot.
My objective is to offload a Nortel switch currenlty trunked from my 3550 and shit the hosts on the Nortel to the 2924 XL on a similarly trunked port.
Is what I am attempting even possible with these two versions of Catalysts?
Correct Answer by Leo Laohoo about 7 years 3 weeks ago
If your troubles have been addressed, may I request if you can mark this post as "Answered" and rate our posts?  Thank you very much.
Correct Answer by glen.grant about 7 years 3 weeks ago
  You can get rid of the diag image , its just there for factory troubleshooting and has no function in everyday usage .  Use the 12.X image . It is the right image for the box , just verify the size in flash matches the size of the file you downloaded from CCO.   Then make sure you do the boot statement , "boot system flash:c2900xl-c3h2s-mz.120-5.WC17.bin .  Write mem the config and reload .   For your trunk setup make sure both are using dot1q for the encapsulation ,  early versions of the 2924 used ISL as a default I believe.
The 2900Xl will only allow ONE IOS.  There's not enough flash space for two.
Correct Answer by jjalexander401 about 7 years 3 weeks ago
Yes, that's the image mine had on it.
System image file is "flash:c2900xl-c3h2s-mz.120-5.WC17.bin"
If you have console access, I'd just set up a tftp server on your laptop and grab the new image from there.  You'll probably have to delete the current image from flash before doing so due to space restrictions.
"no such file or directory"
The file "c2900XL-h2-mz-112.8.2-SA6.bin" is missing.  Do the following at the "switch:" prompt:
1.  flash_init
2.  load_helper
3.  dir flash:
You should see a file with a .bin filename.  If you do, type the command "boot .bin".
When you have successfully loaded the IOS, go into configuration mode and type the following command "no boo system" and save the config.
I am suspecting that you have loaded a new IOS but forgot to change the boot parameters.
Correct Answer by Leo Laohoo about 7 years 4 weeks ago
Can you post the configuration of VLAN 302 of both 2900 and 3550?
Try the following commands on the trunk links for both switches:
switchport mode trunk
switchport trunk encap dot1q
switchport trunk allowed vlan 1,300,302,303,396-398
Get rid of the storm control statement on a trunk link.  Put the this statement on access ports.
Can you also post the output of the "sh ip int brief" on the 2900?  Maybe you have multiple VLANs and, because the 2900 will only allow ONE active VLAN, VLAN 302 is shutdown in favour of other VLAN.
Correct Answer by Giuseppe Larosa about 7 years 4 weeks ago
Hello Acameron12,
do you see that the list of permitted vlans is different on the two sides?
>>switchport multi vlan  1,300,302,303,396-398
>> switchport trunk allowed vlan  300,302,303,396-398
on C3550 do:
int fas0/4
switchport trunk allowed vlan add 1
Hope to help
Giuseppe
Hello Acameron12,
the key message is:
>> Received 802.1Q BPDU on  non 802.1Q trunk FastEthernet0/24 on vlan 300.
the C2924XL may be supporting only ISL trunks, try to use encapsulation isl on the C3550 side
as noted in first post
sh interface fas0/24 switchport should confirm this.
some of older low end switches support only ISL, other ones like C2950 support only 802.1Q
Hope to help
Giuseppe
Hello Acameron12,
this does not mean that the two devices are not building a trunk correctly but it may mean there is a problem with the vlan where the management interface of 2924XL exists.
you should take on both devices (if you can reach the C2924XL with a console connection)
sh interface type 0/y switchport
where type 0/y stands for the port name for example fas 0/23
in this way it is possible to see some of the trunk parameters including encapsulation protocol and native vlan settings
Connecting two ports configured as access ports may solve a native vlan mismatch, or it can join two different broadcast domains
Once a trunk is setup frames sent to C2924 XL management IP address are tagged with a vlan number that may be different from that expected on the C2924 XL making it unreachable.
Hope to help
Giuseppe
Overall Rating: 4.5 (13 ratings)
Correct Answer
Giuseppe Larosa Fri, 04/02/2010 - 12:03
  • Hall of Fame,
    Founding Member
Hello Acameron12,
Hope to help
Giuseppe
acameron12 Fri, 04/02/2010 - 12:39
I do have console access to the 2924 to make configuration changes and IP access to the 3550.
To clarify, I made the following updates to my 2924:
interface FastEthernet0/24
switchport mode multi
On my 3550:
interface FastEthernet0/4
storm-control broadcast level 1.00
When I set the 3550 side of the connection, my 2924 reports:
%SPANTREE-2-RECV_1Q_NON_1QTRUNK:
Received 802.1Q BPDU on non 802.1Q trunk FastEthernet0/24 on vlan 1.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 1.
Inconsistent port type.
%SPANTREE-2-BLOCK_PVID_PEER: Blocking FastEthernet0/24 on vlan 302.
Inconsistent peer vlan.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/24 on vlan 1.
Inconsistent local vlan.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 300.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/24 on vlan 300.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 302.
Received 802.1Q BPDU on non 802.1Q trunk FastEthernet0/24 on vlan 303.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 303.
%SPANTREE-2-BLOCK_.PVID_LOCAL: Blocking FastEthernet0/24 on vlan 303.
Received 802.1Q BPDU on non 802.1Q trunk FastEthernet0/24 on vlan 396.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 396.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/24 on vlan 396.
Received 802.1Q BPDU on non 802.1Q trunk FastEthernet0/24 on vlan 397.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 397.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/24 on vlan 397.
Received 802.1Q BPDU on non 802.1Q trunk FastEthernet0/24 on vlan 398.
%SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/24 on vlan 398.
%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/24 on vlan 398.
Inconsistent local vlan.....
Correct Answer
Giuseppe Larosa Fri, 04/02/2010 - 13:30
  • Hall of Fame,
    Founding Member
Hello Acameron12,
the key message is:
Hope to help
Giuseppe
acameron12 Fri, 04/02/2010 - 13:55
I set the 2924 as:
I set my 3550 as:
switchport trunk encapsulation isl
Still no luck.
Although the 2924 reported no errors.
I can ping my local vlan interface on 2924, but cannot ping across to the 3550.
Correct Answer
Giuseppe Larosa Fri, 04/02/2010 - 14:05
  • Hall of Fame,
    Founding Member
Hello Acameron12,
on C3550 do:
int fas0/4
Hope to help
Giuseppe
acameron12 Fri, 04/02/2010 - 16:51
Hello Guiseppe,
          I updated the 3550 side as suggested:
Still no response frmo the 2924 on a ping request to the VLAN 302 interface:
ping 172.16.200.188
Sending 5, 100-byte ICMP Echos to 172.16.200.188, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Correct Answer
Leo Laohoo Fri, 04/02/2010 - 20:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
acameron12 Mon, 04/05/2010 - 06:09
My 3550 port definition presently looks as follows:
Still no access to the address of the 2924 (172.16.200.188) from the 3550 or in the other direction to the 3550's VLAN 302 interface (172.16.200.129). Although I can still pnig the 2924's local port from the console.
acameron12 Mon, 04/05/2010 - 06:19
See below:
BDC-UNI-INF-SW-G>sh ip int brief
VLAN1 unassigned YES unset up up
VLAN302 172.16.200.188 YES NVRAM up up
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset up up
BDC-UNI-INF-SW-G>
jjalexander401 Sun, 04/04/2010 - 18:25
I  recently set up a trunk between a 2924xl and 2950.  here is my sample config:
2950:
description dot1q trunk link to Lamson (S2 2924) on port fa0/23
switchport trunk native vlan 70
switchport trunk allowed vlan 10,20,30,70
2924:
interface FastEthernet0/23
description dot1q trunk link to Rio (S1 2950) on port fa0/24
switchport trunk allowed vlan 1,10,20,30,70,1002-1005
The 2924 automatically adds 1 and 1002-1005 vlans as allowed.  I couldn't remove them.  I also had to declare vlan 70 as management on the 2924xl, by going to the interface and typing 'management'
hope that helps.
glen.grant Mon, 04/05/2010 - 04:31
  • Purple, 4500 points or more
   Follow jjalexander's config.  Switchport multi setup is not the same as a normal trunk .  It was something cisco used early on on the 2924's to  try and runn mutliple vlans  before  trunking became a standard . If your switch won't take the normal trunking configs then you may have to upgrade the code to 12.X code .   I know the 3550 does not support multi vlan mode.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swvlan.html#wp1030092
acameron12 Mon, 04/05/2010 - 06:31
I was worried about that when I embarked on this task. I have a copy of the image:
Which I downloaded just in case.
I will revert to the original configuration via access rather than trunking from the 3550 and retry subsequent to an image upgrade.
Thanks for the insights.
acameron12 Mon, 04/05/2010 - 06:57
I attempted a reload with a new image, but failed.
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 173 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 3528704
flashfs[0]: Bytes available: 83968
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c2900XL-h2-mz-112.8.2-SA6.bin"...flash:c2900XL-h2-mz-112.8.2-SA6.
bin: no such file or directory
Error loading "flash:c2900XL-h2-mz-112.8.2-SA6.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
switch:
Perhasps I have exceeded the capabilities of this 2924 switch given the environment (paired with a 3550)?
Correct Answer
Leo Laohoo Mon, 04/05/2010 - 14:52
  • Hall of Fame,
    2017 LAN, Wireless
1.  flash_init
2.  load_helper
3.  dir flash:
acameron12 Mon, 04/05/2010 - 16:14
Should I still be able to upgrade to c2900xl-c3h2s-mz.120-5.WC17.bin image and enable compatible trunking functions?
Correct Answer
jjalexander401 Mon, 04/05/2010 - 16:33
acameron12 Mon, 04/05/2010 - 17:42
Ok, I will try the procedure again with your recommendations. I had used tftp to load the new 12.0 image to the 2924. I renamed the existing 11.x image with a .old extension to force a load of the 12.x.
acameron12 Tue, 04/06/2010 - 07:07
I tried the attempted procedure, but:
switch: flash_init
...The flash is already initialized.
switch: load_helper
switch: load_helper
switch:
switch:         dir flash:
Directory of flash:/
2    -rwx  1109398                  c2900XL-h2-mz-112.8.2-SA6.old
3    -rwx  98833                    c2900XL-diag-mz-112.8.2-SA6
4    drwx  10816                    html
175  -rwx  1395                     config.text
177  -rwx  1811903                  c2900xl-c3h2s-mz.120-5.WC17.bin
178  -rwx  323                      env_vars
83968 bytes available (3528704 bytes used)
switch: boot c2900xl-c3h2s-mz.120-5.WC17.bin
Loading "c2900xl-c3h2s-mz.120-5.WC17.bin"...c2900xl-c3h2s-mz.120-5.WC17.bin: per
mission denied
Error loading "c2900xl-c3h2s-mz.120-5.WC17.bin"
switch:
Leo Laohoo Tue, 04/06/2010 - 17:00
  • Hall of Fame,
    2017 LAN, Wireless
This is unbelievable!  How were you able to load TWO IOS into a 2900XL???  It couldn't be done.
Unfortunately, you are in ROMmon and it will be difficult to delete the old IOS.  I would have to recommend you FORMAT the flash and upload the "c2900xl-c3h2s-mz.120-5.WC17.bin" again.
You will need to use the command "formate flash:" to do so.
acameron12 Wed, 04/07/2010 - 00:35
What is the c2900XL-diag-mz-112.8.2-SA6 image and do I need to update that?
Leo Laohoo Wed, 04/07/2010 - 00:52
  • Hall of Fame,
    2017 LAN, Wireless
c2900XL-diag-mz-112.8.2-SA6 is a very, very old IOS.
acameron12 Wed, 04/07/2010 - 01:36
mmm, ok.
Would it make sense to just tftp the old 11.x images off the switch, delete them, leave the 12.x then re-boot?
Correct Answer
Leo Laohoo Wed, 04/07/2010 - 02:14
  • Hall of Fame,
    2017 LAN, Wireless
Correct Answer
glen.grant Wed, 04/07/2010 - 05:23
acameron12 Thu, 04/08/2010 - 07:02
Thanks!
I am making progress:
sh ver
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:27 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C2900XL boot loader
BDC-UNI-INF-SW-G uptime is 14 minutes
System returned to ROM by reload
An the switch now offers trunking options:
(config-if)#switchport ?
  access    Set access mode characteristics of the interface
  mode      Set trunking mode of the interface
  multi     Set characteristics when in multi-VLAN mode
  priority  Set 802.1p priorities
  trunk     Set trunking characteristics of the interface
  voice     Voice appliance attributes
(config-if)#switchport trunk ?
  allowed        Set allowed VLAN characteristics when interface is in trunking
                 mode
  encapsulation  Set trunking encapsulation when interface is in trunking mode
  native         Set trunking native characteristics when interface is in
                 trunking mode
  pruning        Set pruning VLAN characteristics when interface is in trunking
                 mode
acameron12 Thu, 04/08/2010 - 08:34
As of this writing, I have successfully re-applied the original trunking commands to my 2924 and 3550.
I am now able to access the IP address of my 2924 through the 3550 and the trunk access.
The two original 11.x images were removed from the 2924 and the 12.x image remaining in flash with
the boot system command applied to point definitively to the new image.
I have executed several reloads to verify the 2924 can recover access.
Thanks all for your insights and suggestions.
Correct Answer
Leo Laohoo Thu, 04/08/2010 - 15:39
  • Hall of Fame,
    2017 LAN, Wireless
