04-02-2010 12:17 PM - last edited on 03-25-2019 10:48 PM by ciscomoderator
I think the answer is no as I don't see steps to configure this in the SNR guide, but are you able to set time periods that SNR is enabled and disabled automatically? If the answer is no, is that a road map item ?
Not a big deal- just asking for a customer.
Stacy
Solved! Go to Solution.
04-04-2010 06:12 AM
Dear Stacy;
As you suspect, this is not supported. It is only ON and OFF. As per today you can use the UCC Mobility Server option for having advanced SNR functionality.
Alberto
04-04-2010 06:12 AM
Dear Stacy;
Alberto
04-13-2010 01:32 PM
Thank you !
