no dns request forwarding with vlan
Koblensky
Hi all,
i've setup a basic routing infrastructure with vlans, the cisco (GE0/0 208.105.69.43, GE 0/1 vlan local) is attached to the cable modem (208.105.69.41).
if i ping google from the cisco it goes fine:
blackDevil# ping google.it
Translating "google.it"...domain server (24.29.99.35) [OK]
Sending 5, 100-byte ICMP Echos to 209.85.229.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 92/92/96 ms
blackDevil#
but from a local computer i can:
ping 10.0.102.10
PING 10.0.102.10 (10.0.102.10): 56 data bytes
64 bytes from 10.0.102.10: icmp_seq=0 ttl=255 time=1.382 ms
64 bytes from 10.0.102.10: icmp_seq=1 ttl=255 time=1.549 ms
64 bytes from 10.0.102.10: icmp_seq=2 ttl=255 time=1.345 ms
^C
--- 10.0.102.10 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 1.345/1.425/1.549/0.089 ms
but if i try to ping google.it i get "unknown host google.it"
the following is the "debug ip detail accesslist 195"
*Apr  2 18:14:13.348: IP: s=10.0.102.56 (GigabitEthernet0/1.2), d=10.0.102.10, len 55, input feature
*Apr  2 18:14:13.348:     UDP src=60800, dst=53, MCI Check(66), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Apr  2 18:14:13.348: FIBipv4-packet-proc: route packet from GigabitEthernet0/1.2 src 10.0.102.56 dst 10.0.102.10
*Apr  2 18:14:13.348: FIBfwd-proc: Default:10.0.102.10/32 recieve entry
*Apr  2 18:14:13.348: FIBipv4-packet-proc: packet routing failed
*Apr  2 18:14:13.348: IP: tableid=0, s=10.0.102.56 (GigabitEthernet0/1.2), d=10.0.102.10 (GigabitEthernet0/1.2), routed via RIB
*Apr  2 18:14:13.348: IP: s=10.0.102.56 (GigabitEthernet0/1.2), d=10.0.102.10 (GigabitEthernet0/1.2), len 55, rcvd 3
*Apr  2 18:14:13.348: IP: s=10.0.102.56 (GigabitEthernet0/1.2), d=10.0.102.10, len 55, stop process pak for forus packet
*Apr  2 18:14:13.348:     UDP src=46368, dst=53, MCI Check(66), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
as you can see it receives the dns request and the routing fails, do you think is something about vlan routing ? seams strange to me... i didn't yet tried without...here is my configuration:
blackDevil#show run
Building configuration...
Current configuration : 5176 bytes
! Last configuration change at 16:36:02 UTC Fri Apr 2 2010 by admin
version 15.0
hostname blackDevil
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain list mydomain.org
ip domain name mydomain.org
ip host cisco 10.0.102.10
ip name-server 24.29.99.35
ip name-server 24.29.99.36
ip name-server 10.0.102.7
username admin privilege 15 secret 5 $1$..B6$69fkXasdefgEyWTeeogA.
redundancy
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$FW_OUTSIDE$$ETH-WAN$
ip address 208.105.69.43 255.255.255.248 secondary
ip address 208.105.69.46 255.255.255.248
ip broadcast-address 208.105.69.47
duplex auto
speed auto
interface GigabitEthernet0/1
description $FW_INSIDE$
ip address 10.0.101.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.1
description DMZ
encapsulation dot1Q 4
ip address 10.0.104.1 255.255.255.0
interface GigabitEthernet0/1.2
description MZ (trace ny private zone)
encapsulation dot1Q 2
ip address 10.0.102.10 255.255.255.0
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip default-network 208.105.69.41
ip route 0.0.0.0 0.0.0.0 208.105.69.41 permanent
access-list 1 permit 10.0.102.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 195 permit ip 0.0.0.56 255.255.255.0 any
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
what do you think ?
thanks a lot!
kky
Jon Marshall
kky
Where is NAT occuring to change the 10.x.x.x addresses to public internet addresses ? Is it on the cable modem
Also what DNS server is configured on the client. If windows client can you post "ipconfig /all" from the pc.
Can you ping IP internet IP addresses from the client ?
Jon
Jon Marshall
kky
Jon
good questions ! just what i needed on a friday afternoon..
so i've configured the nat and changed the dns from the router to the cable modem and it works !
thanks !!
