Apr 3rd, 2010
Hi guys,
i have one doubt in VM ware ......
Is it possible to communicate from VMware(eg Windows XP) to another VM ware (eg Windows 7)... Its like.....
PC-1 (VM ware(Win XP))-----> PC-2 (VM Ware (Win 7))
Pls reply Guys
Jennifer Halim Sat, 04/03/2010 - 01:27
If your VMWare is connected to a switch port, and you configure those PCs in the same subnet and vlan, they should be able to communicate to each other.
ozzyosbu1 Fri, 04/16/2010 - 05:43
you can have them connected via straight/cross cable ( Ethernet MDI/MDIX Auto Cross feature), and configure the Virtual machine interface to be bridged with the Physical interface.
If you are using NAT mode, then add a staic route for the virtual network of VM on the other host to the other hosts physical interface IP address
