ICMP Port Unreachable from gateway 10.40.25.154 for udp from testserver (10.40.25.175) to 10.20.250.3 port 33440
Apr 3rd, 2010
Sir,
i got this output in Sun Solaris 9server while trying to ping 10.20.250.3 following error message is coming
ICMP Port Unreachable from gateway 10.40.25.154 for udp from testserver (10.40.25.175) to 10.20.250.3 port 33440 what may be the reason.Whether it is server problem or switch Problem.I have attached connectivity diagram.Kindly do the needful at the earliest.
10.20.250.3 is in vlan 1
10.40.25.154 is vlan 2
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
testserver # ping -s 10.20.250.16
PING 10.20.250.16: 56 data bytes
64 bytes from 10.20.250.16: icmp_seq=0. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=1. time=40152. ms
64 bytes from 10.20.250.16: icmp_seq=2. time=39152. ms
64 bytes from 10.20.250.16: icmp_seq=3. time=38154. ms
64 bytes from 10.20.250.16: icmp_seq=4. time=37155. ms
64 bytes from 10.20.250.16: icmp_seq=5. time=36156. ms
64 bytes from 10.20.250.16: icmp_seq=6. time=35157. ms
64 bytes from 10.20.250.16: icmp_seq=7. time=34158. ms
ICMP Time exceeded in transit from 10.40.20.122
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33437
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33438
ICMP Time exceeded in transit from 10.42.20.122
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33439
ICMP Port Unreachable from gateway 10.42.20.154
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33440
64 bytes from 10.20.250.16: icmp_seq=42. time=10036. ms
64 bytes from 10.20.250.16: icmp_seq=43. time=9037. ms
64 bytes from 10.20.250.16: icmp_seq=44. time=8039. ms
64 bytes from 10.20.250.16: icmp_seq=45. time=7040. ms
64 bytes from 10.20.250.16: icmp_seq=46. time=6041. ms
ICMP Port Unreachable from gateway 10.40.20.154
for udp from thirup5med (10.40.20.13) to 10.20.250.16 port 33442
64 bytes from 10.20.250.16: icmp_seq=47. time=5043. ms
64 bytes from 10.20.250.16: icmp_seq=48. time=4044. ms
64 bytes from 10.20.250.16: icmp_seq=49. time=3045. ms
64 bytes from 10.20.250.16: icmp_seq=53. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=54. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=55. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=56. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=57. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=58. time=0. ms
^C
----10.20.250.16 PING Statistics----
59 packets transmitted, 22 packets received, 62% packet loss
round-trip (ms)  min/avg/max = 0/14200/40152
testserver #
Senthil
Ganesh Hariharan Sat, 04/03/2010 - 00:54
Sir,
ICMP port unreachable in genral means an error (the designated protocol is unable to inform the host of the incoming message),but check out the below link on solaris paltform for icmp port unreeachable messages.
http://forums.sun.com/thread.jspa?threadID=5385919
Hope to help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
kumar94437 Sat, 04/03/2010 - 01:10
Sir,
i have checked that link.In server eeprom mac-address is true sir,
Senthil
Ganesh Hariharan Sat, 04/03/2010 - 03:22
Sir,
Senthil
Hi Senthil,
When a datagram is dropped due to expiration of the TTL field, the device that dropped the datagram will inform the source of this occurrence by sending it an ICMPv4 Time Exceeded message,Receipt of this message indicates to the original sending device that there is either a routing problem when sending to that particular destination, or that it set the TTL field value too low in the first place. As with all ICMP messages, the device receiving it must decide whether and how to respond to receipt of the message. For example, it may first try to re-send the datagram with a higher TTL value.
Is the same message coming from your huwei routers also when you ping the 4507 gateway ip address and what is the configurtion in 4507 you have !!
Hope to Help !!
Ganesh.H
kumar94437 Sat, 04/03/2010 - 03:50
Sir,
error messages are not coming While pinging 10.40.250.3 from Huawei switches.
Configuration of 4507 switch is
int vlan 1
ip address 10.40.250.3
int vlan 2
ip address 10.40.25.154
int giga3/25
switch port access vlan 2
Senthil
Ganesh Hariharan Sun, 04/04/2010 - 23:35
Sir,
int vlan 1
int vlan 2
int giga3/25
Senthil
Hi Senthil,
As per the configuration if port 3/25 of ciso 4507 is connected to Huawei router inetrface,then either configure this port as access port or trunk port,so for configuring the trunk check out the below link for the same or remove trunk and then check is ping is breaking intermittently.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010f615.shtml
Hope to Help !!
Ganesh.H
