Cisco 7507 got rebooted with crashinfo.. need help
Apr 3rd, 2010
Hi friends
Our 7507 router got rebooted with crashinfo.. need help to decode and to find the root cause..
Attached below show version and error logs with crashinfo attachment..
=====================Show version==========================
------------------ show version ------------------
IOS (tm) RSP Software (RSP-IK9SV-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 20:51 by dchih
ROM: System Bootstrap, Version 12.0(10r)S1, RELEASE SOFTWARE (fc1)
CB-DR-CR01 uptime is 1 day, 3 hours, 32 minutes
System returned to ROM by reload at 02:13:14 UTC Fri Apr 2 2010
System restarted at 07:43:29 IST Fri Apr 2 2010
System image file is "disk0:rsp-ik9sv-mz.123-26.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco RSP8 (R7000) processor with 131072K/8216K bytes of memory.
R7000 CPU at 250MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
Bridging software.
Primary Rate ISDN software, Version 1.1.
Channelized E1, Version 1.0.
Chassis Interface.
4 VIP6-80 RM7000B controllers (2 FastEthernet)(8 Serial)(40 E1).
1 VIP4-80 RM7000 controller (16 E1).
2 FastEthernet/IEEE 802.3 interface(s)
124 Serial network interface(s)
2043K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 2 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Compiled Mon 17-Mar-08 20:55 by dchih
Slave: Loaded from system
Slave: cisco RSP8 (R7000) processor with 131072K bytes of memory.
===============================Show inventory====================
------------------ show inventory ------------------
NAME: "7507mx chassis, ID:60307762", DESCR: "7507mx chassis"
PID: 132 , VID: Hardware Version : 1.01, Board Revision : A0, SN: 60307762
NAME: "Line Card 0", DESCR: "Versatile Interface Processor (VIP6-80)"
PID: VIP6-80 , VID: Hardware Version : 2.03, Board Revision : B0, SN: 34143559
NAME: "Card Slot 0, Bay 0", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : B0, SN: JAE0943NXNY
NAME: "Line Card 1", DESCR: "Versatile Interface Processor (VIP6-80)"
PID: VIP6-80 , VID: Hardware Version : 2.03, Board Revision : B0, SN: 34250368
NAME: "Card Slot 1, Bay 0", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : B0, SN: JAE0943NRDJ
NAME: "Card Slot 1, Bay 1", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : B0, SN: JAE0943NXQS
NAME: "Line Card 2", DESCR: "R7000"
PID: RSP8 , VID: Hardware Version : 1.07, Board Revision : A0, SN: 34251995
NAME: "RSP at Slot 3", DESCR: "R7000"
PID: RSP8 , VID: Hardware Version : 1.7, Board Revision : A0, SN: 34251982
NAME: "Line Card 4", DESCR: "Versatile Interface Processor (VIP6-80)"
PID: VIP6-80 , VID: Hardware Version : 2.03, Board Revision : B0, SN: 34250459
NAME: "Card Slot 4, Bay 0", DESCR: "Dual Port FastEthernet (RJ45)"
PID: PA-2FE-TX , VID: Hardware Version : 1.1, Board Revision : A0, SN: JAE0933JBWV
NAME: "Card Slot 4, Bay 1", DESCR: "8 Port Serial Adapter ( V35)"
PID: PA-8T-V35 , VID: Hardware Version : 1.17, Board Revision : A0, SN: 34050247
NAME: "Line Card 5", DESCR: "Versatile Interface Processor (VIP6-80)"
PID: VIP6-80 , VID: Hardware Version : 2.03, Board Revision : B0, SN: 33826297
NAME: "Card Slot 5, Bay 0", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : C1, SN: JAE1009X3ZN
NAME: "Card Slot 5, Bay 1", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : C0, SN: JAE1004UHN9
NAME: "Line Card 6", DESCR: "Versatile Interface Processor (VIP4-80)"
PID: VIP4-80 , VID: Hardware Version : 2.04, Board Revision : A0, SN: 35411523
NAME: "Card Slot 6, Bay 0", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : C1, SN: JAE11054GQF
NAME: "Card Slot 6, Bay 1", DESCR: "8 port, software configurable Multichannel T1/E1 without TDM Port Adapter"
PID: PA-MC-8TE1+ , VID: Hardware Version : 3.0, Board Revision : C1, SN: JAE11054GPM
======================================Error in crashinfo============================
Apr 2 07:43:01 IST: %SYS-3-MGDTIMER: Previous timer has bad forward linkage, timer = 44835D40.
-Process= "CallMIB Background", ipl= 0, pid= 151
-Traceback= 404A4F80 404A52A8 4084DFE8
Apr 2 07:43:01 IST: %SCHED-3-UNEXPECTEDTIMER: Unknown timer expiration, timer = 42D01D38, type 17602.
-Traceback= 4084E038
07:43:03 IST Fri Apr 2 2010: TLB (load or instruction fetch) exception, CPU signal 10, PC = 0x40999250
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 40999250 40999FAC 4017AB94 401E0430 401E1908 401CB624
$0 : 00000000, AT : 42CA0000, v0 : 4084B644, v1 : 00000000
a0 : 0C127250, a1 : 44835D38, a2 : 00000000, a3 : 00008676
t0 : 00000030, t1 : 3400E701, t2 : 34008700, t3 : FFFF00FF
t4 : 00000083, t5 : 3E840024, t6 : 00000400, t7 : 43907704
s0 : 00000000, s1 : 44835D38, s2 : 4084B644, s3 : 448BDBF0
s4 : 43610000, s5 : 448BDBF0, s6 : 44830AA4, s7 : 42140000
t8 : 4485282C, t9 : 00000000, k0 : 30408401, k1 : 30410000
gp : 42CA3D90, sp : 4485279C, s8 : 00000000, ra : 40999FAC
EPC : 40999250, ErrorEPC : 0AA60045, SREG : 3400E703
MDLO : 00000001, MDHI : 03300440, BadVaddr : 0C12729A
DATA_START : 0x420F9430
Cause 00000008 (Code 0x2): TLB (load or instruction fetch) exception
=== Start of Crashinfo Collection (07:43:03 IST Fri Apr 2 2010) ===
For image:
regards
Amar
Giuseppe Larosa Sat, 04/03/2010 - 05:11
  • Hall of Fame,
    Founding Member
Hello Amar,
from the information you have attached:
You have likely hit a SW bug
I will give a look at bug  toolkit and will update this post
Hope to help
Giuseppe
