Ping problem on MPLS
Apr 3rd, 2010
Dear Gurus,
I have this weird scenario, wherein i can see the mac-address of both my CE routers but i cannot ping them.
CE1----metro----PE--------PE--------metro ------CE2
On the metro, i can see both mac-address, but we cannot ping each other. Im using EoMPLS only for the mpls network.
tnx.
Federico Coto F... Sat, 04/03/2010 - 10:16
On both CE1 and CE2 you have the correct static or dynamic routes to reach the other end?
Can you check the IP routing table? If you try a traceroute, where does the PING packet die?
Do you have access to the PE routers or are they managed by your provider?
Federico.
