Multicast issue
Apr 3rd, 2010
hi all;
i'm wondering a strange issue with multicast, i explain: i have configured two Cisco 1841 CE for multicast to do a membership with the multicast group, i joined the group but when i initiate a multicast traffic from a PC (Source), i don't receive it from the PC (destination), my configuration and traces are attached to
best regards;
m.elmaaroufi Sun, 04/04/2010 - 07:22
Hi all;
please note that the PE routers are from Juniper,
any help will be appreciated
Edison Ortiz Mon, 04/05/2010 - 12:15
Clear mroute table on both routers with the command 'clear ip mroute'.
At the receiver, initiate the join to the group and from the sender activate the application for group
Once you do that, please post the 'show ip mroute' from both routers along with 'show ip pim neighbor' and 'show ip pim rp-mapping'.
Also, what type of application are you using for the mcast test?
