04-04-2010 06:33 PM
I am still learning and I hope this is an ok place to post questions. I am taking the ICND2 in 4 days and I am more than ready for it. Right now I'm playing with VPN and just wanted to know if this would work. I have the following network...
ISP > FA0/0 2621XM FA0/1 > FA0/1 3524XL
3524XL various ports > LAN Hosts
3524XL FA0/3 > FA0 1721
I have a static IP from the ISP assigned to 2621XM / FA0/0 and overloaded NAT for the lan hosts to access the internet
I have another static IP with static NAT to the ip of the 1721 / FA0 interface
Will the following config work for VPN access to my network? It's like "Router on a Stick" for Vlans but it's for VPN.
Current configuration : 1076 bytes
version 12.4
hostname BYRD-VPN-RTR
boot-start-marker
boot-end-marker
enable secret 5 $1$E0QR$WT1eRKKUvvIjgsKMsH9Y8.
no aaa new-model
resource policy
ip cef
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
username ronald password 0 gsxr
interface FastEthernet0
ip address 192.168.10.3 255.255.255.0
speed 100
interface Virtual-Template1
ip unnumbered FastEthernet0
ip mroute-cache
peer default ip address pool VPN_CLIENTS
ppp encrypt mppe 40
ppp authentication ms-chap
router eigrp 1
network 192.168.10.0
auto-summary
ip local pool VPN_CLIENTS 192.168.10.91 192.168.10.99
no ip http server
no ip http secure-server
snmp-server community public RO
snmp-server community private RW
control-plane
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
password ****
login
end
Solved! Go to Solution.
04-04-2010 07:39 PM
The 1721 should be the default gateway for all the internal hosts. Yes, the configuration should work.
04-04-2010 07:04 PM
I would suggest that you configure the ip pool in different subnet than your LAN subnet.
Are you trying to terminate the PPTP on fa0, and your internal LAN is also fa0? as the current configuration doesn't match up with the network description that you have.
04-04-2010 07:27 PM
Yes, only one interface. I have 192.168.10.91 - 192.168.10.99 excluded in the DHCP pool of the 2621XM.
I believe the description I gave is correct. The 1721 router which I provided the cnf for has only one connection to the 3524XL.
04-04-2010 07:39 PM
