nseto Wed, 04/07/2010 - 16:57
My 3102 has two punch outs (look like a T), see if yours has that and you can punch those out so that you can put two small screws in a wall and hang the unit via the punch outs.
abdelrahman.tarzi Sun, 07/21/2013 - 09:25
I've tried punching them out.. just distorted the back.. then I tried carefully drilling through the back (thereby destroying one unit)..
Why didn't CISCO punch them out (while putting some barrier between the intended screws and the PCB)? I need to hang these! The only way I see now is removing the rubber (sticking) covers to the screws holding the unit together.. removing the entire back.. the trying to drill holes - this is not a typical solution - is there some point on these punchouts that will yield?
Related Content
