Multicast issue
Answered Question
Apr 5th, 2010
Hi all;
i want to implement Multicast SM into an architecture with 2 CE Cisco 1841, i did the configuration as mentionned in the Cisco Documentation, and i realize the registration in the Multicast Group 224.1.1.1 with one RP, but when i initiate a multicast traffic from a machine source i did not receive it in the machine destination, for more details i implement IGMP between CE and machine PC, and PIM between routers,
please note that the others PE are Juniper, you can find a traces attached to this mail
best regards
Med
Correct Answer by Marwan ALshawi about 6 years 10 months ago
HI
first of all the bellow command is needed at all and you have to remove it from both routers
ip igmp join-group 224.1.1.1
however if you want to make sure that the ISP and your routers passing mcast traffic you can do the follwoing
add the above command under the lan interface of the CE2
ping the group address 224.1.1.1 and source the ping from the lan interface you have to recive a reply from CE1 to make sure your mcast working
another issue you have in your config is the bellow static muticast route
ip mroute 192.168.10.10 255.255.255.255 10.43.54.70
This need to be removed you dont need this in your topology this is needed only if you have the source of the multicast reachable via multiple interfaces and the unicast routing using another interface ( RPF check)
in your case i am assuming if you do show ip route all the routing in your routing table has a next hop of the PE 2 ip address 10.43.54.65
if you want a static multicast route you can use the bellow
ip mroute 192.168.10.10 255.255.255.255 10.43.54.65  -- PE 2
again its not required
try to make the changes above then do the ping of mcast group as described above
by the way your server ( the source) supposed to send the traffic to 224.1.1.1
the receiver need to join this group inorder to recieve that traffic
good luck
if helpful Rate
Overall Rating: 5 (1 ratings)
Marwan ALshawi Mon, 04/05/2010 - 05:22
can you please post a simple diagram describing the source and receiver of mcast traffic
with copy of both routers multicasting config
Correct Answer
Marwan ALshawi Tue, 04/06/2010 - 00:40
HI
good luck
if helpful Rate
