MPPE encrytion dial platform
Answered Question
Apr 5th, 2010
I have cisco AS5400XM with 12.4 (25a) IOS version but it seems that MPPE is not supported on this IOS version. Is anybody knows which is the lattest version supported on this platform that supports MPPE. It will be much appriciated
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
IOS Train 12.4 (22)T,YB and YB1 Trains  (ENTERPRISE PLUS IPSEC 3DES,IP PLUS IPSEC 3DES,INT VOICE/VIDEO IPIPGW, TDMIP GW LI and IP PLUS IPSEC 3DES)  in AS5400XM is having the support for PPTP with MPPE.
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Mon, 04/05/2010 - 06:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to help !!
Ganesh.H
mrbzumrbzu Mon, 04/05/2010 - 06:25
Hi Ganesh,
Thanks for reply. Can you please help me how to get such type of information. Is the cisco provides any tool to check the features in IOS?
Tauseef
Ganesh Hariharan Mon, 04/05/2010 - 06:30
Hi Ganesh,
Tauseef
Hi Tauseef,
Yes cisco provide some of the tool in there site for CCO id's and Cisco Feature Navigator tool is one the thing which help us to choose or to find ios or platform as per the requirement.
Which has lots of options for selecting like you can choose withrespect to platform,software,image,feature or product code etc.
Hope to help !!
Ganesh.H
