MeetingPlace Express Version: 2.1.1.2
Answered Question
Apr 5th, 2010
Hi all,
I have Cisco Unified MeetingPlace Express Administration Center
System Version: 2.1.1.2 installed, i went thru the guide on http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/1_2/english/administration_/guide/cm12otlk.html#wp1016353
to get outlook add-in, but in vain. can any1 knows how to find ms outlook add-in for mpe.
Correct Answer by William Bell about 7 years 2 months ago
In regards to the table you posted.  You want to doublecheck this part:
"If you do not install the exchange license, you cannot integrate Cisco Unified  MeetingPlace Express with  Microsoft Outlook. One exception is that if  the systemsoftware license is not installed, Microsoft  Outlook functionality is  enabled for trial and demonstration purposes."
Basically, this is saying that if you have not installed the systemsoftware license then you will have the MS Outlook functionality for trial/demo purposes.  If you have installed the systemsoftware license, then Outlook functionality is not available to you.  Unless, you install the "exchange" license.
Based on your screen shots and your statement that you have already installed the system software, I'd say that you have one more step.  You need to install the "exchange" software license.  If you do not have this license, then you need to check your purchase order to see if it was supposed to be sent to you.  Your AM or SE should be able to clear that up for you.  I believe the part number you would be looking for (if you use CUWL that is) is MPE-OUTLOOK-UWL.  I am not sure what the part number is for non-CUWL deployments.
HTH.
Bill
Please remember to rate helpful posts.
Overall Rating: 5 (1 ratings)
William Bell Mon, 04/05/2010 - 06:00
  • Purple, 4500 points or more
First, you will need to have the appropriate license installed on the MPE system. Then the outlook plugin is a download URL in the end user interface (on your MPE system). Check this URL for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/meetingplace_express/2_0/e...
HTH.
Bill
sohaildxbfze Mon, 04/05/2010 - 13:24
thx bell for informative reply,
but I can not see Outlook add-in option on my mpe server at all under "system config" page, so i was never able to download or install that add-in to my pc. hence to "meetingplace tab". Cisco is also refering me the same procedure & url for help.
William Bell Mon, 04/05/2010 - 13:27
Are you sure you have the appropriate licensing added to the system?
Bill
sohaildxbfze Mon, 04/05/2010 - 13:40
how to check this licensing, as cisco says it comes free with my mpe version i.e.2.1.1.2. moreover m attaching snapshot of my mpe system config option & cisco posted procedure to integrate with ms exchange.
sohaildxbfze Mon, 04/05/2010 - 13:49
further see the findings from internet
http://docwiki.cisco.com/wiki/Cisco_Unified_MeetingPlace_Express,_Release_2.x_--_About_Licenses#License_Restrictions
Under Section
Table: Licenses for Cisco Unified  MeetingPlace Express
License Description
exchange
The exchange license enables you to integrate your Cisco  Unified MeetingPlace Express system with a Microsoft Exchange Server.  This allows your users to schedule and manage meetings from the  Microsoft Outlook Calendar and send and receive Microsoft Outlook  Calendar notifications.
The exchange license is a non-counted license, which means it  is either set to Yes or No.
It means i already have system software installed so Y m not getting Exchange config option in mpe?????
Correct Answer
William Bell Mon, 04/05/2010 - 14:06
HTH.
Bill
William Bell Mon, 04/05/2010 - 13:58
You were quick!  See my post with the attachments to see the license name you should be looking for.  Sorry to say, but based on your screen shot of the license output, you aren't licensed for Exchange add-in.
Bill
William Bell Mon, 04/05/2010 - 13:56
You can see licenses under Maintenance>Licenses>License Summary.
You will need to ensure that the row with the "name" Exchange has a value of "1".  Based on your screen shots I suspect it does not.  As you don't have the "Outlook Plugin Configuration" option under the System Configuration menu, nor do you have the "Exchange Server Configuration" under the System Configuration>E-mail Service Administration.
The Exchange feature is not licensed by default, it may be part of a bundle you purchased, but it is (or at least was) a separate license.
HTH.
Bill
