T1 DSU/CSU compatible
Answered Question
Apr 5th, 2010
Does anyone know if the T1 DSU/CSU card is compatible with a VWIC-2MFT-T1? We are going to use it as a data t1.
Correct Answer by DialerString_2 about 7 years 3 weeks ago
Yes.  I've tested this in my lab but with a homemade t1 xover.
Are these devices going to be at the same location? I'm just curiuos as to what excatly your doing, that's all - don't mean to poke..
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 04/05/2010 - 11:37
  • Hall of Fame,
    Founding Member
Please state the exact part number and on which router model you intend to use it.
cowetacoit Mon, 04/05/2010 - 12:19
The new card is a WIC-1DSU-T1-V2. The WIC-1DSU-T1-V2 will be in an 1841 and the VWIC-2MFT-T1 is already in a 2821. Can these two cards interface with each other? Standard RJ48 T1 cable?
Correct Answer
DialerString_2 Mon, 04/05/2010 - 12:44
  • Bronze, 100 points or more
cowetacoit Mon, 04/05/2010 - 12:50
data point to point t1 in seperate physcial locations.....slow i know.
DialerString_2 Mon, 04/05/2010 - 12:58
That all depends on the bandwidth and the amount of traffic going across. If you need help or configs to set this up let me know.
Good Luck..
cowetacoit Mon, 04/05/2010 - 13:09
I have a few other P2P T1s configured but just not with this particular card. thanks for the help.
