ā04-05-2010 07:12 AM
I' am trying to achieve that when I do a "wr" a backup config is copied to my TFTP server.
My archive config looks like this:
archive
path tftp:172.23.106.30/$h
write-memory
When I do a "wr" I get this debug output:
3550_poe#wr
Building configuration...
[OK]
3550_poe#
Apr 5 14:06:33.899: backup_running_config
Apr 5 14:06:33.899: Current = 1
Apr 5 14:06:33.899: Writing backup file tftp:172.23.106.30/3550_poe-1
Apr 5 14:06:35.731: backup failed
3550_poe#sh archive
The next archive file will be named tftp:172.23.106.30/3550_poe-1
Archive # Name
1 :Error - Bad file number
I don't know why this is not working. I tried FTP too, without luck.
The TFTP server is working, I tested it:
3550_poe#copy running-config tftp:
Address or name of remote host []? 172.23.106.30
Destination filename [3550_poe-confg]?
7196 bytes copied in 0.948 secs (7591 bytes/sec)
I tried this config too, with the root folder of the TFTP server and it is still not working:
archive
path tftp:172.23.106.30/TFTP-Root/$h
write-memory
Do you guys have an idea why this is not working?
PS. I tried it on a 3550 SW, 2960 SW and 2811 Router and it is always the same error.
Solved! Go to Solution.
ā04-05-2010 07:37 AM
ā04-05-2010 07:36 AM
Check if you have enough rights/permissions on the destination host to create a new file
ā04-05-2010 08:25 AM
Thank you very much.
It was the //, I really did not thought about that.
You typed h$ but it should be $h, it is probably a type-o.
Thank you again.
ā04-05-2010 08:27 AM
Glad it worked...yep..I typed it wrong sorry about that.
Remember to rate posts that help and if it solved your problem note that as well. It will help other if they have the same issue.
Mike
