Cisco Router 2811
This is a dump of show version, please can you check for me if this has VPN enabed ? Thanks
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3a), RELEASE
Technical Support:
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 30-Sep-05 13:24 by hqluong
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Router uptime is 3 weeks, 1 day, 3 hours, 32 minutes
System returned to ROM by reload at 14:46:23 UTC Sun Mar 14 2010
System image file is "flash:c2800nm-ipbase-mz.124-3a.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FCZ094870Z6
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Jon Marshall Mon, 04/05/2010 - 11:31
You have IP Base feature set which does not support IPSEC ie. VPNs.
The tool to use for this is Feature Navigator -
Feature Navigator
Click on the link above and then select "Search by Platform". This will bring up a new window where you can select your device ie. 2811 and from then on it's pretty self-explanatory ie. choose your IOS version, yours is 12.4(3a) and then choose a feature set which supports IPSEC.
Note there may well be a charge for upgrading your feature set, you need to check with your Cisco var.
