04-05-2010 07:40 AM - edited 03-06-2019 10:28 AM
There are many ESX hosts in our network environment. As default,we configure two NICs on ESX hosts as Teaming for Active/Active mode
. We also set up etherchannel on the switch end. They are working fine.
Like the following configurations:
interface Port-channel6
switchport trunk allowed vlan 10,86
switchport mode trunk
interface GigabitEthernet1/0/19
channel-group 6 mode on
interface GigabitEthernet2/0/19
But the right now they would like yo change NICs teaming as Active/Standby mode on ESX host.Could you please let me konw how to change switch end? Should we still use etherchannel for it? Thanks for your two cents!
04-05-2010 08:31 AM
If the 2 NICs are connected to the same switch then you can't use etherchannel, you will have to configure them as separate L2 trunks. Ideally if you are using active/standby you want the NICs to be going to 2 separate switches which are interconnected via a L2 trunk.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
04-05-2010 08:43 AM
Thanks for your quick reponse. Right now the NICs in the Teaming are connected to different stack member switch. But it is logical one switch. So the A/A mode is working to us with etherchannel.
According to your suggestion, I rquire to remove the port-channel and keep the trunk settings if we still keep the current port connection, is it right?
Thanks again!
04-05-2010 08:50 AM
Thanks again!
Yes you need to break up the etherchannel but still configure both server links as L2 trunks.
Jon
04-05-2010 08:58 AM
Thanks, I will let you know if it is working tomorrow.
