Translation Help
Answered Question
Apr 5th, 2010
I was able to get a translation to work on all inbound numbers, but I have a single fax on fxs0/1/0 that is getting lost in that translation.  Can someone assist in a translation that would see the fax number (555)555-1112 and point it off to the fxs?
voice translation-rule 50
rule 1 /\(.*\)/ /317\1/    ------fax getting lumped in with this
voice translation-profile inbound
translate called 50
dial-peer voice 101 pots
destination-pattern .T
port 0/0/0:23
forward-digits all
dial-peer voice 115 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 112 pots
dial-peer voice 200 voip
translation-profile outgoing inbound
destination-pattern 555.......
session protocol sipv2
session target ipv4:10.173.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
Correct Answer by paolo bevilacqua about 7 years 3 months ago
You don't need any translation. Just place the number as it comes from telco, as destination-pattern in the DP pots for the relevant port.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Mon, 04/05/2010 - 14:51
  • Hall of Fame,
    Founding Member
Walter Solano Sun, 04/18/2010 - 12:25
  • Gold, 750 points or more
Coul you please let me know how many digits are you getting from the PSTN as DNIS to know how to manipulate them in the proper way. You could find that information in the output of the "debug voice ccapi inout"
Walter   Solano
CCNA Voice
UCCX  Specialis
jgorman1977 Tue, 04/20/2010 - 10:47
Walter,
The telco was bringing in 7 digits and the SIP server required 10. That was the issue.
Walter Solano Tue, 04/20/2010 - 11:26
I tested the translation and its doing the translation in the proper way, but since the fax calls are coming into a different port we need either create another incoming dial-peer for that or apply the translation rule to the voice port itself.
You could find more information about how to map the translation rules to the dial-peer or voice ports:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con7
Please if you need futher help, collect the follow debugs to know exactly whats going on:
Debug voice ccapi
Debug voice trans
