Ethernet Cable Minimum Length
Apr 5th, 2010
I have two SRW2048 switches.  I see the admin guide has maximum cable length requirements, but are there minimum length requirements between devices as well?  I've heard about a 2.5m minimum length but don't know if that is always true, or only sometimes true.  In particular the following combinations are of interest to me:
Switch <-> PC
Switch <-> Switch
Switch (LAG) <-> Switch (LAG)
Normally the Switch <-> PC length will be long, but in a few instances I have servers in the same room as the switches, so the cables are sometimes shorter.  LAG <-> LAG lengths are short because the switches are next to each other on the rack.  Are the requirements likely to change with other brands or models of switch?
Gerald Vogt Tue, 04/06/2010 - 00:49
There is no mininmum for ethernet. I have used 25cm cables without problems.
