Load balance multiple URLs on single VIP
Answered Question
Apr 5th, 2010
I have a fairly typical load balance configuration on a pair of ACE appliances running (A3)2.5 and now I need to load balance multiple URIs to these same servers on port 80 to the one VIP. Can someone direct me to a doc that shows a good example of this, or explain it below?
Dave
serverfarm host application
rserver webserver1 80
probe server-80-PROBE
inservice
rserver webserver2 80
inservice
sticky ip-netmask 255.255.255.255 address source application-80-STICKY
replicate sticky
serverfarm application
class-map match-all application-80-CLASS
2 match virtual-address 1.1.1.1.1 tcp eq www
policy-map type loadbalance first-match application-80-POLICY
class class-default
sticky-serverfarm application-80-STICKY
insert-http X-Forwarded-For header-value "%is"
class application-80-CLASS
loadbalance vip inservice
loadbalance policy application-80-POLICY
loadbalance vip icmp-reply
nat dynamic 22 vlan 424
appl-parameter http advanced-options CASE_PARAM
Correct Answer by Sean Merrow about 6 years 9 months ago
Okay, then.  You don't need a separate Layer-7 policy-map then.  You would do it something like this:
serverfarm host application-80
  rserver server1 80
    inservice
  rserver server2 80
    inservice
serverfarm host application-L7
  rserve rserver1 80
    inservice
  rserver server2 80
    inservice
  2 match virtual-address 1.1.1.1 tcp eq www
class-map type http loadbalance match-any application-L7-CLASS
  3 match http url /uri1/
  4 match http url /uri2/uri2
  5 match http url /uri2/uri3.htm
  class application-L7-CLASS
    serverfarm application-L7
  class class-default
policy-map multi-match POLICY-424
This way, your three sites will be load-balanced to one serverfarm, and all the rest of the traffic would be load-balanced to the default serverfarm.
Hope this clears it up.  Let me know if it doesn't.
Sean
Overall Rating: 5 (2 ratings)
Sean Merrow Mon, 04/05/2010 - 13:42
Hi Dave,
Yes, you can load balance multiple URLs to the same VIP and serverfarm.  You can see how to configure this in the Defining a URL for HTTP Load Balancing chapter in the configuration guides.  I have also included an example below that may help get the concept across.
In this example, the client will be load balanced to the LOGIN-FARM if they come in requesting the URL /login, /register, or they are connecting to Host login.example.com.  If none of those match, we'll check to see if they have a suggestion by looking to see if they are looking for the /suggestions URL.  If so, they will be load balanced to SUGGESTION-FARM.  Lastly, if they don't match either of the first two, then they will be sent to the WWW-FARM.  I think the LOGIN class-map is what you are looking for where multiple URLs will be sent to the same farm.
serverfarm host WWW-FARM
  probe TCP
  rserver WWW_SERVER_01
    inservice
  rserver WWW_SERVER_02
    inservice
  rserver WWW_SERVER_03
    inservice
serverfarm host LOGIN-FARM
  probe TCP
  rserver LOGIN_SERVER_01
    inservice
serverfarm host SUGGESTION-FARM
  probe TCP
  rserver SUGGESTION_SERVER_01
    inservice
class-map match-all WWW-VIP
  2 match virtual-address 192.168.20.10 tcp eq www
class-map type http loadbalance match-any LOGIN
  2 match http url /login
  3 match http url /register
  4 match http header Host header-value login.example.com
class-map type http loadbalance match-any SUGGESTIONS
  2 match http url /suggestions
policy-map type loadbalance first-match SLB_LOGIC
  class LOGIN
    serverfarm LOGIN-FARM
  class SUGGESTIONS
    serverfarm SUGGESTION-FARM
  class class-default
    serverfarm WWW-FARM
policy-map multi-match CLIENT_VIPS
  class WWW-VIP
    loadbalance policy SLB_LOGIC
Let me know if this answers your question.
Sean
dpastor Mon, 04/05/2010 - 14:44
Sean,
Thanks.
So, if I have three known URIs, am I correct in saying that I should be able to use the one serverfarm and then the one class-map with the IP and then add the multiple uris to it?  Or, do I need to have a second serverfarm and class-map?
Dave
  probe TCP
    inservice
    inservice
  3 match http url /site1
  4 match http url /site2
  5 match http url /site3
dario.didio Tue, 04/06/2010 - 00:26
your are mixing things up here. You cannot combine the matching of a VIP address with the mathing of an HTTP URI.
The class-map that matches a VIP address is a layer3/4 class-map. It maches IP Address + port numbers.
The class-map that matches HTTP URI or other HTTP headers for example is a layer7 class-map
You will need something like this:
  probe TCP
    inservice
    inservice
class-map match-all WWW-VIP-L3
class-map type http loadbalance match-any WWW-VIP-L7
policy-map type loadbalance first-match WWW-VIP-PM
class  WWW-VIP-L7
serverfarm WWW-FARM
policy-map multi-match VIPS
class WWW-VIP-L3
  loadbalance policy WWW-VIP-PM
  loadbalance vip icmp-reply active
HTH,
Dario
dpastor Tue, 04/06/2010 - 06:08
Dario,
Thanks for straightening me out on that, I see it now.
Dave
Sean Merrow Wed, 04/07/2010 - 05:19
Hi Dave,
In addition to Dario's comment, you mention multiple sites.  So with the example config you currently have from this thread, it would assume the following:
www.example.com/site1
www.example.com/site2
www.example.com/site3
However, if you truly have multiple sites, and not just multiple URLs representing a different site, such as:
www.site1.com
www.site2.com
www.site3.com
Then your layer-7 class-map might look something more like this:
class-map type http loadbalance match-any MULTI-SITE
  2 match http header Host header-value www.site1.com
  3 match http header Host header-value www.site2.com
  4 match http header Host header-value www.site3.com
HTH,
Sean
dpastor Wed, 04/07/2010 - 07:02
Sean,
I will be using the same FQDM just different /uris, so this is what I am configuring:
I also have a question about the class statement, do I add another class statement the same way you add another when using multplie ports to the same VIP?
class application-URL-80-CLASS
loadbalance policy WWW-VIP-L7
Thanks again,
Dave
Sean Merrow Wed, 04/07/2010 - 07:09
Hi Dave,
Your config will look like the one that Dario provided.  The classes added under the multi-match policy are your layer3/4 classes.  Your three sites are within a layer-7 class-map, which is used within a service policy (layer-7 policy-map), which is applied to the layer3/4 class-map.
I hope I haven't just confused you  ;- )
Sean
dpastor Wed, 04/07/2010 - 08:33
Sean,
Maybe a little confused.
I have built the new serverfarm, policy-map and class-map in bold, I am just not sure how it gets referenced. Do I add it to the multi-match class statement?  My complete config for this particular app is below.
Dave
  rserver server1 80
    inservice
  rserver server2 80
    inservice
  rserve rserver1 80
    inservice
  rserver server2 80
    inservice
  class class-default
policy-map type loadbalance first-match application-L7-POLICY
Sean Merrow Wed, 04/07/2010 - 08:51
Hi Dave,
Is your newly added config going to the same VIP 1.1.1.1:80  ?
Sean
Correct Answer
Sean Merrow Wed, 04/07/2010 - 09:21
  rserver server1 80
    inservice
  rserver server2 80
    inservice
  rserve rserver1 80
    inservice
  rserver server2 80
    inservice
  class class-default
Sean
dpastor Wed, 04/07/2010 - 09:31
Sean,
That definitely clears it up, I will add it to the ACEs and test it later today.  Thanks for all your help.
Dave
Sean Merrow Wed, 04/07/2010 - 09:34
Additionally,  your URLs will only be matched if they are exactly what you have:
If your clients may start their connection to a URL that only begins with those listed above, then you may want to add wildcards to the end using regular expressions, as such:
  3 match http url /uri1/.*
  4 match http url /uri2/uri2.*
  5 match http url /uri2/uri3\.htm
HTH,
Sean
dpastor Wed, 04/07/2010 - 10:57
Sean,
That does help, thanks again.  The app is very specific on the /uri, but that is a good tip and I will keep the wildcard in mind should we need it.
Dave
