MWI Not Working
Apr 5th, 2010
Hello all.
I have an issue with a UC520 running vers. 7.1.3 with 504g phones running firmware 7-4-3.  MWI is not working.  I have read the other issues related to this and these don't seem to fit our issue.  We have checked the Ephone-dn's and they are correct, we have checked the gateway and it is correct.  Frankly, we're at a loss.   Attached is the SIP debug.  Any help you can provide is appreciated.
Steven Smith Mon, 04/05/2010 - 12:23
  • Gold, 750 points or more
Can you post your config?  I see a SIP 500 error.
Remember to remove passwords.
rowseyba1 Mon, 04/05/2010 - 12:27
As do I.  I've checked all ACL's and taken those off that I thought were blocking the mwi from going through.  Here is the config.
Steven Smith Mon, 04/05/2010 - 12:36
I think this is the problem, you have
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
But, you don't have a source group for internal IP's.
Something like...
voice source-group CCA_SIP_SOURCE_GROUP_INTERNAL
access-list 2
translation-profile incoming SIP_Incoming
ACL 2 already exists.  Just looks like the CCA voice source group internal was deleted.
rowseyba1 Mon, 04/05/2010 - 12:51
That list was actually in there, but we had the same issue, same debug.
EDIT:  To clarify, we had the SIP internal source list in(but took it out), we got the same result without it as with it.
Steven Smith Mon, 04/05/2010 - 12:59
I checked again and do not see this in your configuration.
access-list 2
Is this in there?
Steven Smith Mon, 04/05/2010 - 13:10
To see if it is a source group problem, could you temporarily disable both source groups and try again.
rowseyba1 Mon, 04/05/2010 - 13:50
That fixed the issue.  I have left both of the SIP groups off and secured the SIP traffic via the incoming ACL on the WAN interface.  Thanks for your help Steven!
