Busy-Out PRI's on MGCP Gateway
mike-greene
Level 4
Level 4
One of our customers needs us to busy out there PRI's while they install voice firewalls.  There running CUCM 4.1 and the gateways are all MGCP.  I found the document below and I have a couple questions about the gateway reboot in step 6.  Can I do this reboot ahead of time to get ready and is it safe to leave the settings after they do there install or should I change it back?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008076f8d2.shtml
I hope you guys have done or seen this before.
Thanks, Mike
William Bell
I don't think you need to reboot the physical gateway. You simply need to enable status polling on the MGCP endpoint (in CUCM configuration mode) and do a reset on the gateway from CUCM. No reboot should be necessary.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill
Thanks Bill.
