04-05-2010 01:40 PM
When I run discovery LMS finds everything in the range I specify but only says 2 are reachable. The reachable devices are ones that I previously used as seeders. I verified SNMP credentials are good. Any reason why this is happening? No errors that I can find. Versions below and thanks for any help:
Solved! Go to Solution.
04-05-2010 02:22 PM
This is the problem, you only have one target: 10.1.1.0. LMS will only try to match the community against this target. Change the target to "*.*.*.*", this will include all devices and all will show "reachable" now. Assuming that community you have matches what the device has of course.
04-05-2010 02:06 PM
Post a screenshot of CS > Device and Credentials > Device Discovery > Discovery Settings > SNMP Settings.
04-05-2010 02:19 PM
SNMP Settings below. Also I have used individual addresses instead of the network address with the same result.
04-05-2010 02:22 PM
04-05-2010 02:49 PM
OK. They are reachable now. Getting inventory and image will come in time I suppose. Thanks for the assist - much appreciated.
