Natting virual IP of MS Exchange Cluster
mo shea
Hi...
I wanted to know whether creating a static translation for a virtual IP representing clustered MS Exchange 2003 servers actually works or needs to be done in a different way. I have tried when the servers are in DMZ or inside of the ASA 5520 but the result is the same, no communication. I just want to know that fundamentally translating a virtual IP is viable or not, so I know where to proceed after that.
All help is appreciated
Mo Shea
2 Accepted Solutions
I don't see why doing a 1-to-1 static NAT for a virtual IP would be a problem.
If you do STATIC PAT, you can have issues, but with STATIC NAT I don't see why.
What's exactly the issue that you're facing?
Federico.
Jon Marshall
Mo
There is no reason why it cannot be done as long as you are not changing port numbers as Federico says. We have done this with VIPs for http farms before and it works fine.
Jon
Federico.
Jon Marshall
Mo
Jon
Thanks for the feedback,
I checked the setup again (its actually for a customer) and it seems they have installed a Bluecoat appliance infront of the ASA, probably have to review its configuration. All MS Exchange cluster setups that I had done before were published on MS ISA, the latter being natted by the ASA, but this setup is a little bit different. I will post the outcome once the setup is up and running.
Thanks again.
