ASA 5505 Introduction
Apr 5th, 2010
Data VLAN 192.168.3.0
Voice VLAN 10.50.50.0
DHCP Server with both  ranges is 192.168.3.201
Gateway Linksys: 192.168.3.254
Switch  configuration: -
ip routing
no ip domain-lookup
vlan  2-3
interface FastEthernet0/1
description *****Link to  2801*****
switchport trunk  native vlan 2
switchport mode trunk
duplex full
speed 100
spanning-tree portfast
interface FastEthernet0/2
description *****DHCP Server*****
switchport access vlan 2
switchport voice vlan 3
interface FastEthernet0/33
description *****Martyn's IP Phone*****
switchport mode access
shutdown
interface FastEthernet0/44
description *****AP*****
switchport trunk allowed vlan 1-3
interface  FastEthernet0/48
description *****LINKSYS*****
interface Vlan1
no ip address
interface  Vlan2
description *****Data*****
ip address 192.168.3.250  255.255.255.0
interface Vlan3
description *****Voice*****
ip address 10.50.50.250 255.255.255.0
ip helper-address  192.168.3.201
AP Configuration
dot11 vlan-name Data vlan 2
dot11 vlan-name  Voice vlan 3
dot11 ssid Data
   vlan 2
   authentication  open
   guest-mode
dot11 ssid Voice
   vlan 3
    authentication open
power inline negotiation prestandard  source
bridge irb
interface Dot11Radio0
no ip  address
no ip route-cache
encryption vlan 3 key 1 size  128bit 7 E3BEDBF2515AF471C34CFBB0 transmit-key
encryption vlan 3  mode wep mandatory
encryption vlan 2 key 1 size 128bit 7  2E17A6E62FA4D039AD5B57BB transmit-key
encryption vlan 2 mode wep  mandatory
ssid Data
ssid Voice
station-role root
interface Dot11Radio0.2
encapsulation  dot1Q 2 native
ip helper-address 192.168.3.250
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no  bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip  route-cache
bridge-group 3
bridge-group 3  subscriber-loop-control
bridge-group 3 block-unknown-source
no  bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio1
no  ip address
no ip route-cache
shutdown
encryption vlan 3  key 1 size 128bit 7 E3BEDBF25198471C34CFBB0 transmit-key
encryption vlan 2 key 1  size 128bit 7 2E17A6E65A4D039AD5B57BB transmit-key
ssid Data
ssid Voice
no dfs band block
channel dfs
station-role root
interface  Dot11Radio1.2
no ip route-cache
bridge-group 1
interface Dot11Radio1.3
no ip route-cache
bridge-group 3
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.2
no ip route-cache
bridge-group 1
interface  FastEthernet0.3
no ip route-cache
bridge-group 3
interface  BVI1
ip address 192.168.3.244 255.255.255.0
no ip route-cache
The above is working  well but I want to introduce an ASA and remove the Linksys, my ASA only  has 3 VLAN's with the key I have, so VLAN 1, 2 and 3
So my  question to the experts here is "how do I introduce it with my current  config?"
Thanks for your time
Martyn
You actually only have 2.5 VLANs with the 5505.  If you use the .5 vlan it has to restrict traffic flow to 1 of the vlans.
Also you can create additional vlans but you can not associate them with access-list or NATing.
You have a couple options.
1) You buy a 5510
2) you use the following setup
WAN = vlan 2 (default for asa5505 -- from memory)
LAN = vlan 1 (aslo default for asa5505 -- from memory)
VOIP = vlan 3 (you will create this)
When you create the VOIP vlan you will choose to restrict flow to VLAN 1 (LAN).  If you have a call manager then you will need to place the call manager server in vlan 3 with the VOIP.  When you need to access the call manager just plug into a vlan3 port or change a port to vlan 3 for a short period of time.
Cisco is currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Federico Coto F... Fri, 04/09/2010 - 08:24
If you have an ASA 5505 with base license, you have the INSIDE and OUTSIDE interfaces and a DMZ (with limited access to only another interface).
If you purchase a Security Plus license, then you will have 3 fully usable and routable interfaces on the 5505.
Federico.
