Personal prompts for TCL Script
Apr 5th, 2010
I´m using clid_authen_collect TCL system applicattion which is working fine, but I'll like to record my own prompts and replace for the ones is working, but don't know how to call to this prompts, the TCL always uses the .au files (enter_account.au and enter_pin.au) from the system.
Any idea how to fix this??
Juan Carlos Arias
paolo bevilacqua Tue, 04/06/2010 - 09:55
  • Hall of Fame,
    Founding Member
Either edit the script and change the names, or record your own under the default names.
For easy recording, you can use the Recoder script that I wrote:
http://www.ciscoscripts.com
Juan Carlos Ari... Tue, 04/06/2010 - 10:14
Thanks for your answer, but I already record my own prompts under the default names, and still playing the system prompts. Actually there are none .au files on flash, don´t know the source of the file to modified.
