Silent Intercom to Transfer?
Apr 5th, 2010
A couple of our clients would like to be able to intercom direct to a user without ringing prior to transfering a call? So instead of hitting tranfer and then it ringing, they want it to initiate a 1 to 1 intercom to talk without it ringing prior to transfering? Is there any easy way to do this?
I have a LLLOOOOONG WorkAround, but there has to be away to change the transfer options globally?
This is mostly for the receptionist with her side car...
Any help is appreciated!
Steven DiStefano Thu, 04/08/2010 - 07:01
You can use CCA for this (CCA 2.2.2 is latest release).  You can select auto anser or not.
Related Content
