c3750-ipbasek9-tar.122-25.FZ.tar
vpersaud001
Level 3
Level 3
I need this IOS for a 3750 switch but can't find it anywhere to download. I'm assuming if I can see it in the MIB locator here http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=2165&PlatformSel=188&fsSel=617 then the tar file must be available somewhere.
Any ideas? Any help will be greatly appreciated. Thanks.
Vincent
8 Replies 8
Reza Sharifi
Hello Vincent,
This image is not available on CCO for download.  The only 12.2(25) version I see is "c3750-ipbasek9-tar.122-25.SEE3.tar"
The latest version on CCO is 12.2(53) c3750-ipbasek9-tar.122-53.SE1.tar.
Overall 12.2(25) is pretty old
Reza
Ganesh Hariharan
Vincent
Hi Vincent,
Reza is right, as per cisco feature navigator also above mentioned image is not available for download.
Ganesh.H
vpersaud001
Level 3
Level 3
Hi Ganesh and Reza,
Thank you both. I don't think 12.2(53) c3750-ipbasek9-tar supports the integrated wireless controller. I've already checked a few IOSes and can't find any other than the .FZ series that does. If you know of any please let me know.
Thanks. Vincent
Hi Ganesh and Reza,
Thanks. Vincent
Hi Vincent,
Following IOS support wireless lan controller support as per cisco navigator search:-
Features     Wireless LAN Controller Support
Software     IOS
Major Release
Release
Platform
Feature Set/License(s)
Release     Platform     Feature Set/License     Image Name                                                   DRAM     Flash
Sort By:
12.2(25)FZ    CAT3750    ADVANCED IP SERVICES    c3750-advipservicesk9-mz.122-25.FZ.bin     128    16
12.2(25)FZ    CAT3750    IP BASE    c3750-ipbasek9-mz.122-25.FZ.bin                                         128    16
12.2(25)FZ    CAT3750    IP BASE W/O CRYPTO    c3750-ipbase-mz.122-25.FZ.bin                       128    16
12.2(25)FZ    CAT3750    IP SERVICES    c3750-ipservicesk9-mz.122-25.FZ.bin                              128    16
12.2(25)FZ    CAT3750    IP SERVICES W/O CRYPTO    c3750-ipservices-mz.122-25.FZ.bin              128    16
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh,
Thank you for doing that research. Unfortunately I still can't find the IOS file to download. If you search for any of the .FZ files in the main download page it returns 0 found.
In Software Advisor I get error message: There is no single image that supports all your selected software features", although I only selected wireless controller.
Any advise.
Thanks. Vincent
Ganesh,
Any advise.
Thanks. Vincent
Vincent,
You are right the mentioned image by cisco navigator search are not having a download option.
Ganesh.H
Thanks again. My question is if it's not available on CCO how can I get it? I have to have that particular IOS.
UPDATE: The .FZ series are deferred and can only be obtained via special file access granted by Cisco when requested. I have the files needed. Thanks for the input.
