How to choose which mac-address has lower value in STP
Answered Question
Apr 5th, 2010
Hi all,
i was reading in cisco books that for selecting root bridge for STP we choose bridge id with lower value.
i know bridge is made of priority + mac addess .
Lower is better for priority and mac address.
i just need to know while looking at following mac address how do we decide which  has lower value
1>0010.7bcc.733a  and  0010.7bcc.7347  which has lower value ?
2>0010.7bcc.7320   and 0010.7bcc.732d       which mac address is lower?
3>0013.8039.9500
0013.80d7.d580
0013.8030.5e80
0013.80c7.9700    which is lower from these 4 and why?
Also want to make sure if switch A  fastethernet is connected to switch b gigabit port then bandwidth cost will be 19 of that link  or sum of 19 + 1 =20?
many thanks
mahesh
Correct Answer by Ganesh Hariharan about 7 years 1 month ago
Thanks for reply
so in this case which we will use
0013.8039.9500
0013.80d7.d580
0013.8030.5e80
0013.80c7.9700    as per your note 0013.8030.5e80is lower so that we choose?
thanks
Hi Mahesh,
You are right the lowest mac among the above is 0013.8030.5e80 just check from left to right with decimal value for each bit you will end in lower mac-address and in STP the bridge ID is used to elect the root bridge in the STP domain as well as to determine the root port for each of the remaining devices in the STP domain.it will elected automatically as per the election and exchange of BPDU packets.
If you want to manually wants to configure a switch as root bridge as per your environment then change the pirority of the switch.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Reza Sharifi about 7 years 1 month ago
Hi Mahesh,
Just compare the numbers together until you get to the first number that are not alike, whichever is lower that is the lower MAC address
0010.7bcc.733a
0010.7bcc.7347
3 is lower then 4 so the first one is lower
0010.7bcc.7320
0010.7bcc.732d
0 is lower than d so the first one is lower.
It will negotiate the link to 100 so the link cost should be 19
Gig is 4
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Mon, 04/05/2010 - 19:48
  • Cisco Designated VIP,
    2017 LAN
Hi Mahesh,
0010.7bcc.733a
0010.7bcc.7347
0010.7bcc.7320
0010.7bcc.732d
Gig is 4
Reza
mahesh18 Mon, 04/05/2010 - 20:55
Thanks for reply
0013.8039.9500
0013.80d7.d580
0013.8030.5e80
thanks
Correct Answer
Ganesh Hariharan Mon, 04/05/2010 - 21:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks for reply
0013.8039.9500
0013.80d7.d580
0013.8030.5e80
thanks
Hi Mahesh,
Hope to Help !!
Ganesh.H
mahesh18 Mon, 04/05/2010 - 23:31
Hi Reza and Ganesh.
thanks a lot for your reply
mahesh
